Trying to load Database values on StartUp
1586
08-07-2014 09:43 AM
KeithAnderson
Folks
If you get a chance please point me the way on loading dynamic values into the app, on startup, from an external SQL Server db.
Effort in the txt file
Thanks
Keith
Tags (1)
JoshHevenor
It looks like you're on the right track. I moved where you return your promise:
function GetDatabaseValue(_newcity) {
                var def = new Deferred();
                var c = _newcity;
                var qTask = new QueryTask("http://localhost:6080/arcgis/rest/services/ggov_DatabaseValues/MapServer/2");
                var QT = new Query();
                QT.returnGeometry = false;
                QT.outFields = [
                    "CityName", "Html", "Picture", "Link", "Extent"
                QT.where = "CityName = '" + c + "'";
                qTask.execute(QT, function (results) {
                    //console.log(results);
                    var CityExtent;
                    var resultItems = [];
                    var resultCount = results.features.length;
                    for (var i = 0; i < resultCount; i++) {
                        var featureAttributes = results.features.attributes;
                        for (var attr in featureAttributes) {
                            if (attr == "Extent") {
                                CityExtent = featureAttributes[attr];
                                //console.info(CityExtent + " GetDatabaseValue");
                    def.resolve(CityExtent);
// REMOVE -->       return def.promise;
                }); //End of function results
                return def.promise;             // <------ ADD
            } // End Function GetDatabaseValue()
JoshHevenor
                var c = _newcity;
                QT.outFields = [
                    var CityExtent;
KeithAnderson
Josh
Thank you good friend!
Keith
