Trouble with scaleBarUnit for PrintTemplate
1485
07-23-2012 01:56 PM
spencermartin
I'm using the following code to define the print template but I can't get the scalebarunit to display anything other than Miles and KM.
var layouts = [
            "name": "Letter ANSI A Landscape",
            "label": "Landscape (PDF)",
            "format": "pdf",
            "options": {
              "legendLayers": [], // empty array means no legend
              "scaleBarUnit": "Feet",
              "titleText": printTitle
Any suggestions?
SharathNarasimhan
Even I am facing the same problem, Any suggestions on changing the font/font-size of the legend and the text symbols that are displayed in the map ?
JianHuang
You need to create your own print layout template and add it to the print service to change the font and other map components.
JavaScript doesn't have the ability to change them.
SharathNarasimhan
Thanks for this information. This helps a lot !
