Trouble Using Reactive Utils On Initially Undefined Variable
1292
9
05-19-2026 01:36 PM
JasonBartling1
I have a global variable for highlight handles that I'm trying to watch to update a label with the number of currently selected features.  However, the variable is initially undefined and this seems to be causing an issue.  Even if I set the watch options to initial is true, the code will only execute the first time.  Is there a way for me to run it initially and then continue to monitor once the variable is defined? This is my code:
reactiveUtils.watch(()=> globalThis.highlightHandles?._groups.size, () =>{
  const numSelected = globalThis.highlightHandles?._groups.size;
  selectedCount.innerText = numSelected;
  console.log("Num selected is "+numSelected);
  if (numSelected){
    selectedCount.style.color = 'black';
    moreActionsButton.disabled = false;
  else {
    selectedCount.innerText = "0";
    selectedCount.style.color = '#c9c9c9';
    moreActionsButton.disabled = true;
},{initial: true});
Any help would be greatly appreciated!
ReneRubalcava
Esri Frequent Contributor
The reactiveUtils only work against the SDK classes, not native objects and arrays, so we can't watch for changes on `globalThis`. The root object in the watchExpression needs to be an SDK class.
MatthewDriscoll
Try using a when before the watch.  Might want to use a {once: true} for the when.
reactiveUtils.when(
  () => globalThis.highlightHandles != null,
      () => globalThis.highlightHandles._groups.size,
JasonBartling1
Unfortunately, that does not seem to work.  This is the updated code:
reactiveUtils.when(()=> globalThis.highlightHandles != null, ()=>{
  reactiveUtils.watch(()=> globalThis.highlightHandles._groups.size, () =>{
    const numSelected = globalThis.highlightHandles._groups.size;
    if (numSelected){
    else {
MatthewDriscoll
Try creating the variable like this instead.  Also _groups would make it private, so the API might not see it as observable.
reactiveUtils.when(
      (numSelected) => {...
JeffreyThompson2
MVP Frequent Contributor
This is one of those issues I usually slap a setTimeout() on.
setTimeout(()=> {
    if (numSelected){
    else {
}, 100)
It's not a best practice, but it usually works. Try dialing up or down the wait a few times and see if it works.
GIS Developer
City of Arlington, Texas
ReneRubalcava
JasonBartling1
Thanks Rene.  I did not realize it could only be used to track changes to the SDK objects.  Since I am also using a feature table to highlight, I ended up just watching the featureTable.highlightIds.length property.  This code worked for me:
reactiveUtils.watch(()=> featureTable.highlightIds.length, (numSelected) =>{
  if (numSelected > 0){
  else {
MatthewDriscoll
Try this based off of @JeffreyThompson2 suggestion and what we have learned from @ReneRubalcava .
 setInterval(() => {
  const numSelected = globalThis.highlightHandles?._groups?.size || 0;
  console.log("Num selected is " + numSelected);
  if (numSelected) {
  } else {
}, 250);
RafelMayol
You’ll probably need to watch the object after it’s assigned, because watch() can’t keep tracking an undefined reference reliably. A cleaner approach is to watch the property that changes, or re-register the watcher once highlightHandles gets initialized. The initial: true option only fires once with the current value — it doesn’t wait for future definition changes.
RafelMayol
@FCTV33 You’ll probably need to watch the object after it’s assigned, because watch() can’t keep tracking an undefined reference reliably. A cleaner approach is to watch the property that changes, or re-register the watcher once highlightHandles gets initialized. The initial: true option only fires once with the current value — it doesn’t wait for future definition changes.
