Highlight showing individual polygons (not merged)
451
05-12-2026 02:08 PM
DanielL
When using FeatureLayerView.highlight() and multiple features are highlighted, it appears that the highlight automatically merges neighboring highlights.  This makes it look like two neighboring polygons are one polygon.  And if a large polygon overlaps a smaller polygon, and both are highlighted, there is no way to tell that the underlying polygon is also highlighted.
Is there a way to change this behavior so the highlighted polygons don't visibly merge?
MatthewDriscoll
I ran into that too.  If I remember correctly, it is a compositing behavior in the ArcGIS renderer by design for highlights.  The only solution I came up with was creating a Graphics Layer so I can have full control over it.   Probably a good one to put in the Ideas section.
