Trouble getting the legend to work
1360
07-21-2011 12:46 PM
SwenWaschk
I'm in a bit of a struggle here. I don't seem to be able to get the legend to work here. Maybe i'm overlooking something.
dojo.require("esri.map");
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.dijit.OverviewMap");
dojo.require("esri.toolbars.draw");
dojo.require("esri.toolbars.edit");
dojo.require("esri.dijit.Legend");
    var layer, map, editToolbar, ctxMenuForGraphics, selected, visible = [];
    function init() {
  esriConfig.defaults.map.slider = {left : "23px", top : "65px", width : null, height : "200px"};
  esri.bundle.toolbars.draw.addPoint = "Klik om een punt toe te voegen";
  esri.bundle.toolbars.draw.start = "Klik om te beginnen met tekenen";
  esri.bundle.toolbars.draw.resume = "Klik om verder te tekenen";
  esri.bundle.toolbars.draw.complete = "Dubbelklik om te voltooien";
  esri.bundle.toolbars.draw.freehand = "Druk om te beginnen en laat los om te voltooien";
        var initExtent = new esri.geometry.Extent({"xmin":126966,"ymin":359066,"xmax":198909,"ymax":401108,"spatialReference":{"wkid":28992}});
        map = new esri.Map("map", {extent: initExtent , logo: false});
  //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISDynamicMapServiceLayer("http://atlas.sre.nl/ArcGIS/rest/services/OpenStreetMapZW/MapServer");
        map.addLayer(basemap);
  //Add the layer for the layerlist
        layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://atlas.sre.nl/ArcGIS/rest/services/Gemeentegrenzen/MapServer");
        if (layer.loaded) {
          buildLayerList(layer);
        else {
          dojo.connect(layer, "onLoad", buildLayerList);
  dojo.connect(map,'onLayersAddResult',function(results){
         //add the legend
          var legend = new esri.dijit.Legend({
            map:map,
            layerInfos:[{layer:dynamicLayer,title:"Public Safety"}],
            arrangement:esri.dijit.Legend.ALIGN_RIGHT
          },"legendDiv");
          legend.startup();
  //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
        //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm
        var resizeTimer;
        dojo.connect(map, 'onLoad', function(theMap) {
          dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
            clearTimeout(resizeTimer);
            resizeTimer = setTimeout(function() {
              map.resize();
              map.reposition();
            }, 500);
   //add the overview map
   var overviewMapDijit = new esri.dijit.OverviewMap(
     map : map,
     attachTo : "bottom-right",
     color : "#769dc0",
     visible : true
   overviewMapDijit.startup();
  //add the scale bar
  var scalebar = new esri.dijit.Scalebar(
    map : map,
    scalebarUnit : 'metric'
  dojo.connect(map, "onLoad", createToolbarAndContextMenu)
  dojo.connect(map, "onLoad", createToolbar);
    function buildLayerList(layer) {
  var items = dojo.map(layer.layerInfos,function(info,index){
   if (info.defaultVisibility) {
    visible.push(info.id);
   return "<input type='checkbox' class='list_item' checked='" + (info.defaultVisibility ? "checked" : "") + "' id='" + info.id + "' onclick='updateLayerVisibility();' /><label for='" + info.id + "'>" + info.name + "</label><br>";
        dojo.byId("layer_list").innerHTML = items.join("");
        layer.setVisibleLayers(visible);
        map.addLayer(layer);
    function updateLayerVisibility() {
        var inputs = dojo.query(".list_item"), input;
        visible = [];
        dojo.forEach(inputs,function(input){
   if (input.checked) {
    visible.push(input.id);
  //if there aren't any layers visible set the array to be -1
   if(visible.length === 0){
    visible.push(-1);
 function createToolbarAndContextMenu(map) {
 // Create and setup editing tools
  editToolbar = new esri.toolbars.Edit(map);
  dojo.connect(map,"onClick", function(evt){
   editToolbar.deactivate();
   //navToolbar.deactivate();
  createMapMenu();
  createGraphicsMenu();
 function createMapMenu() {
 // Creates right-click context menu for map
  ctxMenuForMap = new dijit.Menu({
   onOpen: function(box) {
  /*ctxMenuForMap.addChild(new dijit.MenuItem({
   label: "Add Point",
   onClick: function addToMap (geometry) {
    map.showZoomSlider();
    var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,0,0.25]));
    var graphic = new esri.Graphic(geometry, symbol);
    map.graphics.add(graphic);
  ctxMenuForMap.startup();
  ctxMenuForMap.bindDomNode(map.container);
 function createGraphicsMenu() {
 // Creates right-click context menu for GRAPHICS
   ctxMenuForGraphics = new dijit.Menu({});
  ctxMenuForGraphics.addChild(new dijit.MenuItem({
   label: "bewerken",
   onClick: function() {
    if(selected.geometry.type !== "point"){
      editToolbar.activate(esri.toolbars.Edit.EDIT_VERTICES, selected);
    else{
      alert("Niet van toepassing");
   label: "verplaatsen",
    editToolbar.activate(esri.toolbars.Edit.MOVE, selected);
   label: "roteren/schaal",
     editToolbar.activate(esri.toolbars.Edit.ROTATE | esri.toolbars.Edit.SCALE, selected);
    else{
  /*ctxMenuForGraphics.addChild(new dijit.MenuItem({
   label: "Style",
    alert("Not implemented");
  ctxMenuForGraphics.addChild(new dijit.MenuSeparator());
   label: "verwijderen",
    map.graphics.remove(selected);
  ctxMenuForGraphics.startup();
  dojo.connect(map.graphics, "onMouseOver", function(evt) {
     // We'll use this "selected" graphic to enable editing tools
     // on this graphic when the user click on one of the tools
     // listed in the menu.
   selected = evt.graphic;
     // Let's bind to the graphic underneath the mouse cursor
   ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
  dojo.connect(map.graphics, "onMouseOut", function(evt) {
   ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
 function createToolbar(themap) {
   resizeMap();
  toolbar = new esri.toolbars.Draw(map);
  dojo.connect(toolbar, "onDrawEnd", addToMap);
 function addToMap(geometry) {
  toolbar.deactivate();
   switch (geometry.type) {
    case "point":
       break;
    case "polyline":
       var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255,0,0]), 1);
       break;
    case "polygon":
       var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]));
       break;
    case "extent":
       break;
dojo.addOnLoad(init);
Thanks in advance for all your help.
derekswingley1
Try changing "dynamicLayer" to "layer" in your legend's layerInfos object.
SwenWaschk
Thanks, I'll try it a.s.a.p. and let you know if it did the trick.
SwenWaschk
well i've got it working! thanks!
