Trouble getting geometry of projected point...
1380
02-20-2012 05:26 AM
GISAdmin1
I have a simple request to project a point:
var projectedPoint =  gsvc.project([hiddenFacilities], outSR, function(projectedPoints){
 pt = projectedPoints[0];
 return(pt);
var hiddenFacilitiesGraphic = new esri.Graphic(projectedPoint, markerSymbol, attr);
How do I get the geometry of projected point.  I can see the coordinates after inspecting projectedPoint in Firebug.  I just can't seem to use the object to create a graphic.
Thanks in advance,
M
nicogis
on callback or onProjectComplete or dojo.Deferred you get geometry projected
gsvc.project([ point ], outSR, function(projectedPoints) {  projectedPoint = projectedPoints[0]; var hiddenFacilitiesGraphic = new esri.Graphic(projectedPoint, markerSymbol, attr);});
GISAdmin1
I originally had my code structured like this>:
for (var i = 0; i < facilityMaster.length; i++) {
       gsvc.project([hiddenFacilities], outSR, function(projectedPoint){
       pt = projectedPoint[0];
       hiddenFacilitiesGraphic = new esri.Graphic();
       hiddenFacilitiesGraphic.setGeometry(pt);
       hiddenFacilitiesGraphic.setSymbol(markerSymbol);
       hiddenFacilitiesGraphic.setAttributes(i);
       parkNameLayer.add(hiddenFacilitiesGraphic);
The problem is, the projected graphic is not getting the attribute "i" (setAttributes(i)).  The created graphics all have the same attribute.  I need the projected graphics to have a unique value.
Thanks!
nicogis
The behaviour is right because the clousure provided by anonymous function passed to projected doesn't resolve the variable 'i' until it's resolved
GISAdmin1
Can you suggest another approach?  Can I create the graphic with the attributes and then project the graphic instead of just the point geometry?
nicogis
Project has in input array of geometry. You can do your loop into function like:
    pt = projectedPoint;
                hiddenFacilitiesGraphic.setAttributes(...);
