TREE COVER LOSS Url
2909
06-19-2024 07:40 AM
SudeeshNarayanan
Hi! I am very new to ArcGIS Online and I have a question regarding a layer.
"TREE COVER LOSS (annual, 30m, global, Hansen/UMD/Google/USGS/NASA)"
I am trying to feature this particular dataset in my Angular application.
I have tried with 'FeatureLayer' but couldn't find the URL to this feature
JohnGrayson
Esri Alum
That layer is a tiled raster layer so that is why you can't add it as a FeatureLayer.  Here's an SDK sample for how to add wmts layers: https://developers.arcgis.com/javascript/latest/sample-code/layers-wmts/ and here's a codepen showing how to add this specific service: https://codepen.io/john-grayson/pen/WNBzaPx
BernSzukalski
Esri Frequent Contributor
I did a quick search and am thinking this might be the layer you want to use (?):
https://www.arcgis.com/home/item.html?id=7254c77048444a45a5d41cf43445572b
If so it is a WMTS service and you'll find the URL down along the right side of the item overview page:
https://tiles.globalforestwatch.org/umd_tree_cover_loss/v1.8/tcd_30/wmts
If a different layer you are wanting to use, you'll still find the link along the right side of the item overview.
As for Angular, there are a few published how-to articles and videos along with this developer help:
https://developers.arcgis.com/javascript/latest/components-get-started-angular/
https://www.esri.com/content/dam/esrisites/en-us/events/conferences/2020/developer-summit/arcgis-api...
You'll find more via Google search.
SudeeshNarayanan
In Angular I implemented base map and add few polygons. What I wanted to include is this particular data set on the base map.
"Hansen/UMD/Google/USGS/NASA, accessed through Global Forest Watch".
Tried adding via FeatureLayer
const deforestationLayer = new FeatureLayer({
Getting error: 404.
And I tried with online web map. Tried adding "Hansen/UMD/Google/USGS/NASA" to a basemap.
 got the error:
The layer, Tree cover loss with time slider (Hansen/UMD/Google/USGS/NASA), cannot be added to the map."
JohnGrayson
Esri Alum
SudeeshNarayanan
Thanks Will try this
