Transparency of graphics
4096
6
08-22-2014 07:44 AM
TimWitt2
Hey everybody,
Is there a way to change the transparency of a particular graphic or is this only possible for a graphic layer?
Tim
JakeSkinner
Esri Esteemed Contributor
Hi Tim,
If the graphics is already created, you can use the setSymbol method to do this.  Ex:
var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
        new Color([255,0,0]), 2),new Color([255,255,0,0.25])
map.graphics.graphics[2].setSymbol(symbol);
JakeSkinner
Hi Tim,
TimWitt2
Thanks Jake!
TimWitt2
One more question, how does this work if my color is in Hex string?
KenBuja
MVP Esteemed Contributor
According to the documentation, the transparency option is only available for RGB colors
TimWitt2
Thanks Ken, I guess I need to change my color palette then to return RGB values.
KenBuja
You can change the transparency of the color you assign different graphics.
var trans = Math.random();
// lineSymbol used for freehand polyline, polyline and line.
var lineSymbol = new CartographicLineSymbol(
  CartographicLineSymbol.STYLE_SOLID,
  new Color([255, 0, 0, trans]), 10,
  CartographicLineSymbol.CAP_ROUND,
  CartographicLineSymbol.JOIN_MITER, 5
