Hey everybody,
Is there a way to change the transparency of a particular graphic or is this only possible for a graphic layer?
Tim
Solved! Go to Solution.
Hi Tim,
If the graphics is already created, you can use the setSymbol method to do this. Ex:
var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255,0,0]), 2),new Color([255,255,0,0.25])
map.graphics.graphics[2].setSymbol(symbol);
Hi Tim,
One more question, how does this work if my color is in Hex string?
According to the documentation, the transparency option is only available for RGB colors
Thanks Ken, I guess I need to change my color palette then to return RGB values.
You can change the transparency of the color you assign different graphics.
var trans = Math.random();
// lineSymbol used for freehand polyline, polyline and line.
var lineSymbol = new CartographicLineSymbol(
CartographicLineSymbol.STYLE_SOLID,
new Color([255, 0, 0, trans]), 10,
CartographicLineSymbol.CAP_ROUND,
CartographicLineSymbol.JOIN_MITER, 5
