Transfer field value
1267
05-20-2010 02:35 AM
tommykurniawan
I'm try to use field value, from searching result for another javascript calculation.
Could someone help me, on how to transfer those field value from code like below,
var infoTemplate = new esri.InfoTemplate("Info:${Desc}","${Diameter}");
I need to use the  value of ${Diameter}, into javascript variable.
Thank you.
DerekSwingley
Diameter is an attribute for your graphics, correct? If so, when you have access to your graphic, do this:
var dia = graphic.attributes.Diameter;
tommykurniawan
Derek Swingley , Thank you for reponse, i've just found the solution.
by adding the code for accessing the attributes value.
var featureAttributes = featureSet.features[0].attributes;
diam=featureAttributes['Diameter'];
