Token working in Postman but not in web application
964
02-02-2025 07:54 AM
NileshValwaikar
Hello,
I am trying to export a shapefile for a featurelayer which has export enabled. everything is working manually and also from postman, but when i am trying to integrate the same in my javascript web application its giving code 498 Invalid Token. This token is generated fresh having referrer ="*" and expiry of 15days. as said its working in postman but not in my simple HTML code also.
below is a sample snippet of my code...
const formdata = new FormData();
formdata.append("itemId", "33cfb3f2849e4793b6551512e0eddac8");
formdata.append("exportFormat", "Shapefile");
formdata.append("token", "MyTOKEN");
formdata.append("exportParameters", "{\n \"layers\" :[ {\"id\" : 0,\"where\" : \"ward_name = 'Bagahada'\"}]\n}");
formdata.append("f", "json");
formdata.append("title", "testshp4");
const requestOptions = {
method: "POST",
body: formdata,
redirect: "follow"
fetch("https://myportal/portal/sharing/rest/content/users/portaladmin/export", requestOptions)
.then((response) => response.text())
.then((result) => console.log(result))
.catch((error) => console.error(error));
Sage_Wall
Hi @NileshValwaikar , Try removing the referrer configuration or adding the protocol and domain.  The * is only allowed as a subdomain (https://*.your-app.com). If you want to allow it to be used from everywhere just leave the referrer empty.  I believe that it's probably working in Postman because postman likely doesn't send a referrer by default.
nafizpervez
When using FormData, you don't need to manually set the Content-Type header, as it will be automatically set by the browser. However, if you manually set the Content-Type to something like application/x-www-form-url encoded or multipart/form-data, it might conflict with the request.
Remove any manual Content-Type header if it's set in your fetch request.
  method: "POST",
  body: formdata,
  headers: {
    "Referer": "https://your-web-app.com",  // Adjust with your web app URL if necessary
  redirect: "follow"
  .then(response => {
    // Check if the response is ok
    if (!response.ok) {
      throw new Error(`HTTP error! status: ${response.status}`);
    return response.text();
  .then(result => {
    console.log("Export result: ", result);
  .catch(error => {
    console.error("Fetch error: ", error);
