ToJson issue with outline of a symbol
1548
07-14-2014 07:17 AM
AdrianMarsden
Honored Contributor
Hi I have the follow routine that takes a newly made graphic and add the details to Local Storage.  The idea is that it is then retrieved the next time the user uses the application
    var graphic = new esri.Graphic(geometry, symbol);
    console.debug(graphic)
    // store to local storage  graphic added
    var now = new Date();
    var n = now.getTime();
    GraphicName = "storedGraphic" + n;
    window.localStorage.setItem(GraphicName, dojo.toJson(graphic.toJson()));
    console.debug(dojo.toJson(graphic.toJson()));
    graphic.setAttributes({
        newID: GraphicName
    userGraphics.add(graphic);
It works fine, however I have recently given the users the ability to change outline colour.
This then fails.
Looking at my debugs - the first one (line 2 - I do like the new code format here, if nothing else ) returns
Object {geometry: Object, symbol: Object, attributes: undefined, infoTemplate: undefined, declaredClass: "esri.Graphic"…}
  1. _extent: Object
  2. _graphicsLayer: Object
  3. _offsets: Array[1]
  4. _shape: Object
  5. attributes: Object
  6. geometry: Object
  7. infoTemplate: undefined
  8. symbol: Object
    1. _inherited: Object
    2. color: b.Color
    3. outline: Object
      2. color: "#ff0000"
      3. style: "solid"
      4. width: "2"
      5. __proto__: Object
    4. style: "solid"
  9. __proto__: Object
Notice the Colour FF0000 - basically pure red.
Now my second debug line, echoing out the JSON that I store into Local Storage
{"geometry":{"rings":[[[323189.8652275379,87282.84014002334],[326479.760210035,88064.1901983664],[327302.23395565926,84363.05834305717],[323888.9679113185,82430.24504084015],[323189.8652275379,87282.84014002334]]],"spatialReference":{"wkid":27700}},"symbol":{"color":[0,0,0,179],"outline":{"color":[null,null,null,null],"width":1.5,"type":"esriSLS","style":"esriSLSSolid"},"type":"esriSFS","style":"esriSFSSolid"}}
Look at all those nulls !
This means that the feature isn't retrieved properly, and I think may be causing issues with my print routine.
Any ideas anyone?
Cheers
ACM
Edit - yep this has a similar issue on printing - heres the Json of my print request - the same set of nulls
  "featureSet": {
                "geometryType": "esriGeometryPolygon",
                "features": [{
                    "geometry": {
                        "rings": [
                                [310770.51166861143,
                                    83910.69778296383
                                [314677.2619603267,
                                    85473.39789964995
                                [315211.8698949825,
                                    81525.52392065345
                                [313073.4381563594,
                                    81114.28704784131
                                    83910.69778296383
                        "spatialReference": {
                            "wkid": 27700
                    "symbol": {
                        "color": [0, 0, 0, 179],
                        "outline": {
                            "color": [null, null, null,
                                null
                            "width": 1.5,
                            "type": "esriSLS",
                            "style": "esriSLSSolid"
                        "type": "esriSFS",
                        "style": "esriSFSSolid"
AdrianMarsden
Honored Contributor
Sorted
I hadn't converted the outline colour using the same function I used for fill colour
function hexToRgb(hex, alpha) {
    var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
    return result ? {
        r: parseInt(result[1], 16),
        g: parseInt(result[2], 16),
        b: parseInt(result[3], 16),
        a: alpha
    } : null;
this gets it into the correct format for saving a retrieving - I can't remember why!
AdrianMarsden
Honored Contributor
Sorted
    return result ? {
        a: alpha
    } : null;
