Toggle Services Sample Question
1199
04-08-2013 07:03 PM
DanikBourdeau2
Quick question.  In the Legend -toggle Services Sample (http://developers.arcgis.com/en/javascript/jssamples/widget_legendvisible.html) there are two onLayersAddResult events in the JS script.  One is used for the Legend the other for adding the toggle services.
Why have two events, could they not both be in the same event?  What is the advantage to having them in separate events?
StephenLead
Honored Contributor
I think it's just a mistake someone made when copy/pasting separate samples together into one. There's no reason that you'd need two separate functions which could handle the same thing.
Steve
StephenLead
Honored Contributor
Steve
DanikBourdeau2
I kind of figured as much.  Thanks for the response 🙂
