toggle measurement dijit (startup & destroy)
5636
10-23-2011 06:00 AM
PaulJereb
Hello!
I have an issue with toggling the measurement widget: the first time i start the measurement it shows up and works correctly. Also destroying it works. But when I want to activate it another time the Div won't be displayed. What am I doing wrong?
var measurement;
if ((++clickcounter%2) == 0) {
  measurement.destroy();
} else {
  if (measurement == undefined) {
    measurement = new esri.dijit.Measurement({
        map: map,
               defaultAreaUnit: esri.Units.SQUARE_METERS,
        defaultLengthUnit: esri.Units.KILOMETERS
             }, dojo.byId('measurementDiv'));
    measurement.startup();
  measurement.setTool("distance", true);
<div id = "measurementDiv"></div>
KellyHutchins
Esri Notable Contributor
The problem is that when you destroy the measurement widget the measuremntDiv is destroyed too. So when you try to recreate the measurement widget that div no longer exists. Instead of using an existing div you can create a new div to hold the measurement widget and add that to the measurementDiv. Here's an example:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
      Measure Tool
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
      #map {
        border:solid 2px #808775;
        -moz-border-radius:4px;
        -webkit-border-radius:4px;
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:240px;
      .claro .dijitTitlePaneTitle {
        background: #808775;
        font-weight:600;
        border:solid 1px #29201A;
      .claro .dijitTitlePaneTitleHover {
        background:#808775;
      .claro .dijitTitlePaneTitleActive {
        background:#808775;
      .claro .dijitTitlePaneContentOuter {
        border-right: solid 2px #808775 !important;
        border-bottom: solid 2px #808775 !important;
        border-left: solid 2px #808775 !important;
      </style>
      <script type="text/javascript">
        djConfig = {
          parseOnLoad:true
      </script>
      <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.TitlePane");
      dojo.require("dijit.form.CheckBox");
      dojo.require("esri.map");
      dojo.require("esri.dijit.Measurement");
      dojo.require("esri.SnappingManager");
      dojo.require("esri.dijit.Scalebar");
      dojo.require("esri.layers.FeatureLayer");
      var map;
      var measurement;
      function init() {
       //This sample may require a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
        esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
        esri.config.defaults.io.alwaysUseProxy = false;
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
       var initialExtent = new esri.geometry.Extent({"xmin":-9545482,"ymin":4615382,"xmax":-9544248,"ymax":4616059,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", {
          extent:initialExtent
        dojo.connect(map, 'onLoad', function(map) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
        map.addLayer(basemap);
        var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
         new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
         new dojo.Color([195,176,23]), 2),null);
        var parcelsLayer = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer/0", {
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
        parcelsLayer.setRenderer(new esri.renderer.SimpleRenderer(sfs));
        dojo.connect(map, "onLayersAddResult", function(results){
          //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac.
          var snapManager = map.enableSnapping({snapKey:dojo.keys.copyKey});
          var layerInfos = [{layer: parcelsLayer}];
          snapManager.setLayerInfos(layerInfos);
          createMeasure();
        map.addLayers([parcelsLayer]);
      //show map on load
      dojo.addOnLoad(init);
      function tglMeasurementOff() {
      function tglMeasurementOn() {
        createMeasure();
     function createMeasure(){
          map: map
        }, dojo.create('measure'));
        dojo.place(measurement.domNode,dojo.byId('measurementDiv'));
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:'false'"
    style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
       <button id="tglMeasurementOff" type="button" onclick="tglMeasurementOff();">toogleMeasurementOff</button>
      <button id="tglMeasurementOn" type="button" onclick="tglMeasurementOn();">toogleMeasurementOn</button>
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
PaulJereb
I reproduced the issue with modifying the Measurement Example of the JavaScript API Samples (as found here: http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_measurement.html)
All I did was adding two buttons, one to destroy the measurement dijit and one to create and start it up again. As you can see, the functionality of the dijit is there when recreating it (first hit off then on), but the div is not showing up.
I call it a bug until someone proves me wrong 😉
<html>
  <head>
    on iOS devices-->
    <title>
      Measure Tool
    </title>
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        overflow:hidden;
      #map {
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:240px;
        font-weight:600;
        background:#808775;
        background:#808775;
      </style>
        djConfig = {
          parseOnLoad:true
      </script>
      var map;
      var measurement;
      function init() {
          outFields: ["*"]
            map: map
      //show map on load
            map: map
    </script>
  </head>
       <button id="tglMeasurementOff" type="button" onclick="tglMeasurementOff();">toggleMeasurementOff</button>
      <button id="tglMeasurementOn" type="button" onclick="tglMeasurementOn();">toggleMeasurementOn</button>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
KellyHutchins
<html>
  <head>
    on iOS devices-->
    <title>
      Measure Tool
    </title>
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        overflow:hidden;
      #map {
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:240px;
        font-weight:600;
        background:#808775;
        background:#808775;
      </style>
        djConfig = {
          parseOnLoad:true
      </script>
      var map;
      var measurement;
      function init() {
          outFields: ["*"]
          createMeasure();
      //show map on load
        createMeasure();
          map: map
    </script>
  </head>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
AmroAhmed
This solution have issue of creating measure tool every time you click toggle on that are unacceptable behavior so you must add script to enable and disable for toggle On / Toggle Off button
i used the follwoing JQuery
function createMeasure() {
            map: map
        dojo.place(measurement.domNode, dojo.byId('measurementDiv'));
        $('#tglMeasurementOn').attr('disabled', 'disabled');
        $('#tglMeasurementOff').removeAttr('disabled');
PaulJereb
Kelly, thanks a lot, works perfectly!!
