Toggle Map
1641
08-02-2018 10:36 AM
NadirHussain
if (map.getZoom() > 13) {
visFlag = true;
toggle = new BasemapToggle({
map: map,
visible: true,
basemap: "hybrid",
basemaps:
"hybrid": {
"title": "hhh",
"thumbnailUrl": "../Content/images/satellite.png"
"topo": {
"title": "fff",
"thumbnailUrl": "../Content/images/topo.png"
}, "BasemapToggle");
if (toggle) {
console.log("i m inside Visible 13");
toggle.startup();
else {
if (toggle) {
toggle.destroy();
console.log("destroy")
dear all
i want to change the toggle map visibility on extent change.but only one time this happened.But one time toggle map appear and disappear.it not comes second time please help.other thing i also want to display  title of  currently selected map
NadirHussain
tried to register widget with id==BasemapToggle but that id is already registered.this error is also i am getting.
RobertScheitlin__GISP
Nadir,
   Can you add a simple full sample code of this?
NadirHussain
Dear robert
i sovled one issue.
var mapExtentChange = map.on("extent-change", changeHandler);
function changeHandler(evt) {
var extent = evt.extent,
zoomed = evt.levelChange;
var intCount = 0;
if (intCount == 0) {
toggle.startup();
$('#DivBP').css("visibility", "Visible");
intCount++;
else if (intCount > 0)
intCount++;
else {
var baseMapToggle = dijit.byId('DivBP');
$('#DivBP').css("visibility", "hidden");
this is my code.the other issue is when i press toggle on baseMapToggle widget.map layer change.But title not change. this title inside red eclipse never change.how to change.Thanks again.
NadirHussain
Dear Robert
 Thanks.I solved all the issues.i override the toggle method of ToggleBaseMap Class.It solved all my issues.
Thanks
Again.
