Toggle between two layers in c# server application
2592
7
02-08-2011 12:20 AM
ManojrajTeli
I have difficulty regarding the toggling between two layers as i have many layers in my application and i want to toggel betweeen basemap and imagery in my project using two radio button.Please as soon as possible And thank You in advance,
HemingZhu
ESRI has example for this: http://help.arcgis.com/en/webapi/javascript/arcgis/demos/map/map_explicitlayerlist.html
Note: This works for dynamic map services or (feature layer) not the tiled map services.
derekswingley1
It's a pretty simple task to take the Toggle multiple ArcGIS Online services sample and convert it to use a radio buttons instead of normal buttons.
ManojrajTeli
I really new at this and tried this link:http://help.arcgis.com/en/webapi/jav...layerlist.html and i m totally confused about giving local layer address at this point:layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis1/Demo/default.aspx, { "imageParameters": imageParameters });.Please help me out at this point or is there any way round to refer to imagery layer and basemap layer.Is there any way to do this using c# code.Thank you for the your replies.
ManojrajTeli
I have Annotation,Assets,Basemap,Satellite Imagery layer now this is the problem:-At one time i have to show Basemap or Satellite Imagery using the radio button
ManojrajTeli
I have hosted my local service and i want to switch only those layers and not the arcgisserver layers.how to do that...???
ManojrajTeli
I was able to uncheck layers in TOC by doing this
Toc1.Nodes[0].Nodes[0].Checked = false;
Toc1.Nodes[0].Nodes[0].Nodes[0].Checked = false;
Toc1.Nodes[0].Nodes[1].Checked = false;
Toc1.Nodes[0].Nodes[2].Checked = false;
Toc1.Nodes[0].Nodes[3].Checked = false;
Toc1.Nodes[0].Nodes[4].Checked = false;
but the map was not getting refreshed..All the layers were on map.Please help me with this....thank you in advance.
MarioObendorfer
try to link your checkboxes or whatever you use with an event handler ... e.g. 'checkchange'. If you have a dynamic TOC you should give each TOC entry an id, in this case best id is the service id. Save alle services/layers in an array. If checkchange fires you can do something like this:
//Listener on an ExtJS Component
listeners: {
        'checkchange': function(node, checked){
            if(checked){
                node.getUI().addClass('complete');
  var size = node.parentNode.childNodes.length;
  for(var i=0;i<size;i++) {
   if(node.parentNode.childNodes.id != node.id) {
    node.parentNode.childNodes.ui.checkbox.checked = false;
    Ext.getCmp('mappanel).setLayerVisibility(node.parentNode.childNodes.id, false);
   }else {
    Ext.getCmp('mappanel).setLayerVisibility(node.id, true);
           }else{
                node.getUI().removeClass('complete');
//function definition in ExtJS
setLayerVisibility: function(id, visible) {
    var size = this.oLayer.length; //in this array all layers/services are saved
 if(this.oLayer.id == id) {
  if(visible)
   this.oLayer.show();
  else
   this.oLayer.hide();
With this example you activate only one layer/service at a time ... i just c&p parts from an ExtJS  sample of mine and didn't alter it to a common example ... you might have to change some parts.
Summary ... give TOC an evhandler and show/hide layers linked via id to the TOC.
Hope that helps a little bit ... greets Tol
