TOC Widget - Slider is not working
1493
05-14-2014 09:54 AM
EdibertoAlves1
Hi!
I am developing an application using the TOC Widget from this source:
http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/docs/toc/examples.html
However, I'm not getting the slide tool to make transparency. On the moment that the user select the layer that desire to work and the layer is loaded.
Below the code snippet.
var dynaLayer1, dynaLayer2;
var toc, toogleLayer;
require([
"dojo/_base/connect",
"dojo/dom",
"dojo/parser",
"dojo/on",
"dojo/_base/Color",
"esri/map",
"esri/geometry/Extent",
"esri/layers/FeatureLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/symbols/SimpleFillSymbol",
"esri/renderers/ClassBreaksRenderer",
"agsjs/dijit/TOC",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/fx",
"dojo/domReady!",
"dojo/dom-construct",
"dijit/registry"
function (connect, dom, parser, on, Color,
Map, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
SimpleFillSymbol, ClassBreaksRenderer,
TOC, domConstruct, registry) {
     parser.parse();
     var mapServer = dojo.byId('selEmpreendimento'); // options from select with url mapservers
     dynaLayer1 = new ArcGISDynamicMapServiceLayer(mapServer.value, {
         mode: FeatureLayer.MODE_ONDEMAND
    map.on('LayersAddResult', function (evt) {
         toc = new agsjs.dijit.TOC({
             map: map,
             layerInfos: [
             //    layer: featLayer1,
             //    title: "Fotos",
             //    //collapsed: false, // whether this root layer should be collapsed initially, default false.
             //    slider: true // whether to display a transparency slider.
                 layer: dynaLayer1,
                 title: dynaLayer1.layerInfos.name,
         }, 'tocDiv');
         toc.startup();
         map.addLayer(dynaLayer1);
     on(mapServer, 'change', function (evt) {
         dynaLayer2 = new ArcGISDynamicMapServiceLayer(mapServer.value, {
         map.addLayer(dynaLayer2);
         toogleLayer = map.on('LayerAddResult', function (evt) {
             toc.layerInfos.splice(0, 1, {
                 layer: dynaLayer2,
                 title: dynaLayer2.layerInfos.name,
                 slider: true
             toc.refresh();
             toogleLayer.remove();
What I am make wrong?
EdibertoAlves1
Anyone can help?
KenBuja
MVP Esteemed Contributor
Could you put this into something like JSBin to show what exactly is happening?
JeffPace
first glance
your require is out of order.  domReady needs to be last. And you are missing alot of aliases to the require (bordercontainer, fx, etc..)
These need to match exactly.
GauriDeshmukh
Did you get the solution? If You find please post it here.
