ArcGIS Pro
ArcGIS Survey123
ArcGIS Online
ArcGIS Enterprise
Data Management
ArcGIS Experience Builder
Geoprocessing
ArcGIS Web AppBuilder
ArcGIS Field Maps
ArcGIS Dashboards
ArcGIS StoryMaps
All Products Communities
Water Resources
Education
State & Local Government
Transportation
Gas and Pipeline
Water Utilities
Imagery and Remote Sensing (I&RS)
Roads and Highways
Natural Resources
Electric
Telecommunications
All Industries Communities
Python
JavaScript Maps SDK
Native Maps SDKs
ArcGIS API for Python
ArcObjects SDK (Retired)
ArcGIS Pro SDK
Developers - General
ArcGIS REST APIs and Services
Game Engine Maps SDKs
ArcGIS Online Developers
File Geodatabase API
All Developers Communities
Comunidad Esri Colombia - Ecuador - Panamá
Europe
Czech GIS
ArcGIS 開発者コミュニティ
Asia Pacific
Americas
ArcNesia
Esri India
Comunidad GEOTEC
GeoDev Germany
ArcGIS Content - Esri Nederland
All Global Communities
User Groups
Services
Community Resources
Events
Networks
Learning
ArcGIS Topics
View All Communities
ArcGIS Ideas
GIS Life
Community Resources
Show
only
Search instead for
Home
JavaScript Maps SDK
JavaScript Maps SDK Questions
Re: TOC Widget - Slider is not working
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
Translate Now
Subscribe
1481
05-14-2014 09:54 AM
EdibertoAlves1
05-14-2014
09:54 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi!
I am developing an application using the TOC Widget from this source:
http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/docs/toc/examples.html
However, I'm not getting the slide tool to make transparency. On the moment that the user select the layer that desire to work and the layer is loaded.
Below the code snippet.
var dynaLayer1, dynaLayer2;
var toc, toogleLayer;
require([
"dojo/_base/connect",
"dojo/dom",
"dojo/parser",
"dojo/on",
"dojo/_base/Color",
"esri/map",
"esri/geometry/Extent",
"esri/layers/FeatureLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/symbols/SimpleFillSymbol",
"esri/renderers/ClassBreaksRenderer",
"agsjs/dijit/TOC",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/fx",
"dojo/domReady!",
"dojo/dom-construct",
"dijit/registry"
function (connect, dom, parser, on, Color,
Map, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
SimpleFillSymbol, ClassBreaksRenderer,
TOC, domConstruct, registry) {
parser.parse();
var mapServer = dojo.byId('selEmpreendimento'); // options from select with url mapservers
dynaLayer1 = new ArcGISDynamicMapServiceLayer(mapServer.value, {
mode: FeatureLayer.MODE_ONDEMAND
map.on('LayersAddResult', function (evt) {
toc = new agsjs.dijit.TOC({
map: map,
layerInfos: [
// layer: featLayer1,
// title: "Fotos",
// //collapsed: false, // whether this root layer should be collapsed initially, default false.
// slider: true // whether to display a transparency slider.
layer: dynaLayer1,
title: dynaLayer1.layerInfos.name,
}, 'tocDiv');
toc.startup();
map.addLayer(dynaLayer1);
on(mapServer, 'change', function (evt) {
dynaLayer2 = new ArcGISDynamicMapServiceLayer(mapServer.value, {
map.addLayer(dynaLayer2);
toogleLayer = map.on('LayerAddResult', function (evt) {
toc.layerInfos.splice(0, 1, {
layer: dynaLayer2,
title: dynaLayer2.layerInfos.name,
slider: true
toc.refresh();
toogleLayer.remove();
What I am make wrong?
Thanks
Tags
(2)
Tags:
javascript
web_developers
Reply
Kudos
All Posts
Previous Topic
Next Topic
EdibertoAlves1
05-15-2014
06:30 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Anyone can help?
Reply
Kudos
KenBuja
MVP Esteemed Contributor
05-15-2014
09:18 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Could you put this into something like
JSBin
to show what exactly is happening?
Reply
Kudos
JeffPace
05-15-2014
10:10 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
first glance
your require is out of order. domReady needs to be last. And you are missing alot of aliases to the require (bordercontainer, fx, etc..)
These need to match exactly.
Reply
Kudos
GauriDeshmukh
05-26-2014
08:14 PM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Did you get the solution? If You find please post it here.
Reply
Kudos
Post Reply
