TOC Issue
1746
06-04-2014 03:39 AM
deleted-user-yA_w_FC9FKe5
I'm converting from Legacy to AMD.  The last thing I think I need to do is convert my TOC.  It is acting strange at the moment, sometimes it comes in and sometimes it does not.  However, in the legacy it always comes in without any issues.  Really weird.
Am I doing something wrong?  Below is just the TOC code and I put the whole code at jsbin.  Any idea what could be causing this?
http://jsbin.com/cezej/1/edit
dojo.connect(map, 'onLayersAddResult', function(results) {
               //alert("Test")
       var standardTOC = new agsjs.dijit.TOC({
                  map: map
      //noLegend: true
                }, 'standardDiv');
                standardTOC.startup();
    //alert("test2")
    var sliderTOC = new agsjs.dijit.TOC({
                  map: map,
                  layerInfos: [
                    noLayers: true,
     showGroupCount: true,
     layer: flMCY_Stores_Regions,
                    title: "Macy's Stores District"},
        noLayers: true,
                    layer: flMCY_Stores,
                    title: "Macy's Stores Region",
        noLayers: true,
                    layer: dlDRegionDistrictPolygons,
                    title: "Boundary Files",
                    slider: true
      ], style:'inline'
                }, 'sliderDiv');
                sliderTOC.startup();
TimWitt
The AMD version of connect is on, like this:
map.on("layers-add-result", function (results) {
KenBuja
MVP Esteemed Contributor
You're mixing versions of the stylesheets and the version of the JSAPI
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/nihilo/nihilo.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
    <link rel="stylesheet" href="css\MyMobileMaps.css">
      <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.9/js/dojo/dojox/layout/resources/FloatingPane.css">
    <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dojox/layout/resources/ResizeHandle.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/Grid.css">
<script src="http://js.arcgis.com/3.8/"></script>
You also might want to use the latest version of the TOC control
packages: [{
     "name": "agsjs",
     "location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs' // for xdomain load
Also, check your require statement. There are a couple of funky things in there. For example, "dojo/domReady!" should be at the end and doesn't need a corresponding argument in the function. See this blog for more information. Also you have a couple of modules that don't follow the syntax convention of using "/" instead of "."
"dojo.fx",// needed if use jsapi 3.0
"esri.arcgis.utils",
"dijit.form.ToggleButton",
"dijit.TitlePane"
I tried this but still not getting anything:
               //alert("Test")
                  map: map
      //noLegend: true
                }, 'standardDiv');
    //alert("test2")
                  map: map,
                  layerInfos: [
                    noLayers: true,
        noLayers: true,
        noLayers: true,
                    slider: true
      ], style:'inline'
                }, 'sliderDiv');
        //map.addLayers([dlDRegionDistrictPolygons]);
  map.addLayers([dlDRegionDistrictPolygons,flMCY_Stores,flMCY_Stores_Regions,dlMCY_Stores]);
Ken I updated everything you said but still am having the issue.
Did I update everything to be the same versions of the stylesheets and the JSAPI?  I have everything at 3.9!!
    <link rel="stylesheet" href="css\MyMobileMacysMaps.css">
 <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.9/js/dojo/dojox/layout/resources/ResizeHandle.css">
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.10.2/jquery.min.js" type="text/javascript"></script>
    <script>
    var dojoConfig = {
              parseOnLoad: true,
    packages: [{
      "name": "agsjs",
   </script>
 <script src="http://js.arcgis.com/3.9/"></script>
  <script type="text/javascript" src="bookmarks/District_bookmarks.js"></script>
<script type="text/javascript" src="bookmarks/Store_bookmarks.js"></script>
 <script src="jsfiles\Real_Estate_Filters.js"></script>
require([
        "esri/map",
        "esri/graphic",
        "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/Font",
        "esri/symbols/TextSymbol",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dijit/form/Button",
        "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
  "dojox/widget/TitleGroup",
  "dijit/layout/AccordionContainer",
  "dijit/layout/TabContainer",
  "esri/dijit/Bookmarks",
  "esri/dijit/LocateButton",
  "esri/dijit/HomeButton",
  "esri/dijit/BasemapGallery",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/layers/FeatureLayer",
    "esri/dijit/Measurement",
     "esri/dijit/InfoWindowLite",
     "esri/InfoTemplate",
  "agsjs/dijit/TOC",
//Floating Panel
    "dojox/layout/FloatingPane",
 "dojox/layout/Dock",
    "dojox/layout/ResizeHandle",
 "dojo/dnd/move",
 "esri/tasks/query",
//"esri.symbols.SimpleMarkerSymbol",
//Datagrid
"dojo/data/ItemFileWriteStore",
"esri/tasks/QueryTask",
"dojo/_base/Color",
"esri/Color",
"dijit/dijit",
"dojo/fx",
"esri/arcgis/utils",
"dijit/form/ToggleButton",
"dijit/TitlePane",
"dojox/form/CheckedMultiSelect",
        "dojo/domReady!"
      ], function(
        Map, Graphic, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Font, TextSymbol,Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser, BorderContainer, ContentPane, TitleGroup, AccordionContainer, TabContainer, Bookmarks, LocateButton, HomeButton, BasemapGallery, ArcGISDynamicMapServiceLayer, FeatureLayer, Measurement, InfoWindowLite, InfoTemplate, TOC, FloatingPane, Dock, ResizeHandle, move, query, ItemFileWriteStore, QueryTask, Color, ESRIColor, connect, dijit,fx, utils, ToggleButton, TitlePane
