TOC in 3.12
3988
01-29-2015 09:41 AM
RichardMoussopo
is the TOC not working anymore in 3.12 API?
<script src="http://js.arcgis.com/3.12/"></script>
      <script type="text/javascript">
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
                "location": "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs"
    </script>
it worked for 3.11 and now in 3.12 just getting this error even if I access the file locally. the reference is set to: "agsjs/dijit/TOC"
RobertScheitlin__GISP
This is the code that Nianwei Liu uses on their site with 3.12 API
  // helpful for understanding dojoConfig.packages vs. dojoConfig.paths:
  // http://www.sitepen.com/blog/2013/06/20/dojo-faq-what-is-the-difference-packages-vs-paths-vs-aliases/
  var dojoConfig = {
      paths: {
          //if you want to host on your own server, download and put in folders then use path like:
          agsjs: location.pathname.replace(/\/[^/]+$/, '') + '/../src/agsjs'
 </script>
or if you are not hosting it locally then use this:
    var dojoConfig = {
      paths: {
        agsjs: "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs"
  </script>
Richard,
     The TOC dijit does not come from esri and thus the error you are seeing. You are trying to load the toc from http://js.argis.com/3.12/agsjs/dijit/TOC.js and it does not exist at that location as this is a third party dijit.
  var dojoConfig = {
      paths: {
 </script>
    var dojoConfig = {
      paths: {
  </script>
RichardMoussopo
Got it to work,
Thank y' all
