TOC - Arrows instead of plus sign to expand TOC
7509
18
06-15-2016 12:11 PM
BrianFoley1
I want to replace the plus '+' sign with an arrow for the opening and closing of an item in the TOC.  Also, I want to put the arrow to the left of the checkbox.  How can I do this ?
--Brian
BrianFoley1
yes, I changed the code to : <link rel="stylesheet" href="agsjs/dijit/css/toc.css">
this is what my .html page looks like :
then further down, I add a reference to TOC.js :
RobertScheitlin__GISP
Brain,
  That is pretty weird. Can you show me your TOC.css where you added the new rule?
BrianFoley1
Here's TOC.css :
and here's TOC.js :
Brian,
  Everything looks fine. Can you zip-up the whole thing and attach it for review?
BrianFoley1
Robert,
Do you want me to send the zipped file to this email ?
Brian Foley
Brian,
  Yes if you use the advanced editor you will have the ability to attach files to this thread.
BrianFoley1
Robert,
        Here's the zipped file.
Brian
Brian,
  Add this css rule right after the other you added:
.claro .dijitTreeExpandoClosed {
    background-position: 1px 0;
BrianFoley1
Robert,
     Thanks, that did it.   Another question I have is related to the image below.  It is from a WPF Browser Application I was playing with.  I wanted to create something similar in javascript.  Along the top of the map, I have a feature called 'Identify Tools' which when selected drops down a menu with the tools available.  Is it possible to do this in javascript ?  I've been looking at the examples on developers.arcgis.com (javascript) and haven't seen anything similar.
Brian
