TimeSlider
1020
08-10-2021 03:23 AM
arcgispro8
Hi Everyone! I am working on an Arcgis Java Script Api 4.16 based application. I have polygons of an area which is represented by color for different time stamps and daily these polygons are updated. I want to run a time slider in such a way that latest day appear first in the timeslider. Is there any solution for this?
UndralBatsukh
Hi there,
This cannot be done with out of the box timeslider widget. We have an enhancement to animate the data in reverse order. When this implemented you can the set the timeslider to play the animation in reverse order starting from the end/latest date.
-Undral
