Time slider not showing up on web map
3042
05-09-2016 12:19 PM
itsmichael
Hello everyone!
I am trying to make a web map with a time slider via HTML/CSS/JS. The time slider, however, is not showing up despite following the documentation.
Here is part of my code:
       <script src="http://js.arcgis.com/3.16/"></script>
       <script>
        var map;
        require([
        "esri/map", "esri/dijit/InfoWindowLite",
        "esri/InfoTemplate", "esri/layers/FeatureLayer", "esri/dijit/Legend", "esri/dijit/HomeButton",
        "esri/dijit/BasemapGallery", "esri/arcgis/utils", "dojo/_base/array", "dojo/parser",
        "esri/dijit/Scalebar", "esri/TimeExtent", "esri/dijit/TimeSlider", "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane", "dijit/TitlePane", "dijit/layout/AccordionContainer",
        "dojo/dom-construct", "dojo/domReady!"
      ], function(
        Map, InfoWindowLite, InfoTemplate, FeatureLayer, Legend, HomeButton, BasemapGallery, arcgisUtils,
        arrayUtils, parser, Scalebar, TimeSlider, TimeExtent, BorderContainer, ContentPane, AccordionContainer,       domConstruct
        parser.parse();
        map = new Map("map", {
          basemap: "gray",
          center: [-101.15, 37.604],
          zoom
: 9
       // Time Slider
        map.on("load", initSlider);
        function initSlider() {
          var timeSlider = new TimeSlider({
            style: "width: 100%;"
          }, dom.byId("timeSliderDiv"));
          map.setTimeSlider(timeSlider);
          var timeExtent = new TimeExtent();
          timeExtent.startTime = new Date("1/1/1966 UTC");
          timeExtent.endTime = new Date("12/31/2014 UTC");
          timeSlider.setThumbCount(1);
          timeSlider.createTimeStopsByTimeInterval(timeExtent, 2, "esriTimeUnitsYears");
          timeSlider.setThumbMovingRate(2000);
          timeSlider.startup();
          // Add labels at start and end
          var labels = ['1966','2014'];
          timeSlider.setLabels(labels);
          timeSlider.on("time-extent-change", function(evt) {
            var startValString = evt.startTime.getUTCFullYear();
            var endValString = evt.endTime.getUTCFullYear();
            dom.byId("daterange").innerHTML = "<b>" + endValString  + "</b>";
I followed the example from ArcGIS documentation but it is not working on my end.
Thanks in advance!
RobertScheitlin__GISP
Michael,
  You have TimeExtent and TimeSlider reversed in your require parameters list.
      ], function(
It should be:
      ], function(
        arrayUtils, parser, Scalebar, TimeExtent, TimeSlider, BorderContainer, ContentPane, AccordionContainer, domConstruct
Michael,
      ], function(
It should be:
      ], function(
