Tiled Map Usage Statistics
939
10-18-2012 02:10 PM
AaronConnolly
This is a long shot and based on the documentation I've read I'm not sure is even possible, but I'll ask anyway:
Is there a quick and easy way to determine, with the API, how many tiles have been downloaded for a given tiled layer?
- Aaron
derekswingley1
This isn't something that is available via the JS API (at best, it would be on a per session basis, which probably wouldn't be that useful, and then you'd need to persist this info somewhere).
This is something that you could track via your web server logs. The specifics of how to do it will depend on the your web server you're using.
