The value of the property 'require' is null
2392
03-07-2017 12:45 PM
DavidKucharski
I have created a ASP .NET Web Application. I add a new Web Form and put the following code in the aspx page. This is the example in the getting started 2d example on the ESRI web-site. When I run the application I get an error stating 'The value of the property 'require' is null or undefined., not a Function object. Am I doing something wrong or do I need something else. I thought it was a DOM object and having the <script src="https://js.arcgis.com/4.3/"></script> tag would make it accessible. Thanks
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="WebForm1.aspx.vb" Inherits="Map_JavaScript_1.WebForm1" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>Get started with MapView - Create a 2D map</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<script>
require([
"esri/Map",
"esri/views/MapView",
"dojo/domReady!"
], function (Map, MapView) {
var map = new Map({
basemap: "streets"
var view = new MapView({
container: "viewDiv", // Reference to the scene div created in step 5
map: map, // Reference to the map object created before the scene
zoom: 4, // Sets the zoom level based on level of detail (LOD)
center: [15, 65] // Sets the center point of view in lon/lat
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
David,
  What is your compatibility mode set to in your apps meta tag?
David,
DavidKucharski
Robert,
thank you for pointing me in the right direction. My site, for other reasons, was in Compatibility mode. Once I put the meta tag on the mapping site to be compatible with IE 11 it works.
