The right way coding in Vue 3 compositive API
4017
06-26-2022 11:40 PM
baohuachu7
To share the Map or MapView object through the application, what's the right way in Vue 3 dev environment?
To use "Provide/Inject" or "Vuex" state management ?   In this thread  it seems the Js SDK not support proxy so the Map objects are not reactive.   What about the current version of SDK?
Tags (1)
ReneRubalcava
Esri Frequent Contributor
I don't want to dictate it as the right way, but this is an example of how I manage ArcGIS JSAPI in Vue.
https://github.com/odoe/nearby-app/blob/main/src/store.ts
You can also use shallowRef in components for stuff if you like. This will just wrap the instance in a Proxy and not all of it's props
https://vuejs.org/api/reactivity-advanced.html#shallowref
I very much recommend that ArcGIS JSAPI not be referenced directly in components, but again, that is just my opinion.
baohuachu7
Hi Rene:
   What do you mean : ArcGIS JSAPI not be referenced directly in components  ?
   If not use the reactive features for  ArcGIS JSAPI , only those on Vue side use reactive, and use Accessor watch method, or watchUtils     to handle Map or MapView changes.  Is this way OK?  (as discussed in this thread)  .
ReneRubalcava
I prefer to isolate references to the JSAPI in the store or utility modules, but components not to import things like the Map or MapView directly.
baohuachu2
Hi  Rene,
Thank you for your help.
