The new customer featurelayer (ploygon) could not display on the map. Thanks!
2028
8
05-31-2011 06:55 AM
mikezheng
Please see the code as below:
    <script type="text/javascript">
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("esri.map");
        dojo.require("esri.layers.FeatureLayer");
        dojo.require("esri.dijit.Popup");
        dojo.require("esri.arcgis.utils");
        dojo.require("esri.dijit.Scalebar");
        dojo.require("esri.dijit.editing.Editor-all");
        dojo.require("esri.tasks.geometry");
        var gsvc = null;
        var map;
        var featureLayer;
        var resizeTimer;
        var webmap;
        function init() {
            webmap = "da8e773cb68149a39e06f706c6d7cdb2";
            var itemDeferred = esri.arcgis.utils.getItem(webmap);
            itemDeferred.addCallback(function (itemInfo) {
                var initExtent = new esri.geometry.Extent({ "xmin": -12734442.894989174, "ymin": 4942199.239293063, "xmax": -5342676.5117014535, "ymax": 8459525.5328628, "spatialReference": { "wkid": 102100} });
                //create a popup to replace the map's info window
                var popup = new esri.dijit.Popup(null, dojo.create("div"));
                map = new esri.Map("map", {
                    extent: initExtent,
                    infoWindow: popup
                dojo.place(popup.domNode, map.root);
                var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
                map.addLayer(basemap);
                                dojo.connect(map, "onLayersAddResult", function (results) { requestPhotos(itemInfo); });
                                map.addLayers([featureLayer]);
                //create a feature collection for the flickr photos
                var featureCollectionPolygon = {
                    "layerDefinition": null,
                    "featureSet": {
                        "features": [],
                        "geometryType": "esriGeometryPolygon"
                featureCollectionPolygon.layerDefinition = {
                    "geometryType": "esriGeometryPolygon",
                    "objectIdField": "ObjectID",
                    "drawingInfo": {
                        "renderer": {
                            "type": "simple",
                            "symbol": {
                                "type": "esriSFS",
                                "style": "esriSFSSolid"
                    "fields": [{
                        "name": "ObjectID",
                        "alias": "ObjectID",
                        "type": "esriFieldTypeOID"
                        "name": "description",
                        "alias": "Description",
                        "type": "esriFieldTypeString"
                        "name": "imagelink",
                        "alias": "imagelink",
                        "name": "title",
                        "alias": "Title",
                //define a popup template
                var popupTemplatePolygon = new esri.dijit.PopupTemplate({
                    title: "{title}",
                    description: "{description}"
                //create a feature layer based on the feature collection
                featureLayerPolygon = new esri.layers.FeatureLayer(featureCollectionPolygon, {
                    id: 'Building Information',
                    infoTemplate: popupTemplatePolygon
                //associate the features with the popup on click
                dojo.connect(featureLayerPolygon, "onClick", function (evt) {
                    map.infoWindow.setFeatures([evt.graphic]);
                    map.infoWindow.show(evt.mapPoint);
                dojo.connect(map, "onLayersAddResult", function (results) { requestPolygon(itemInfo); });
                map.addLayers([featureLayerPolygon]);
                dojo.connect(map, 'onLoad', function (theMap) {
                    dojo.connect(dijit.byId('map'), 'resize', function () { //resize the map if the div is resized
                        clearTimeout(resizeTimer);
                        resizeTimer = setTimeout(function () {
                            map.resize();
                            map.reposition();
                        }, 500);
        function requestPolygon(itemInfo) {
            var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([151, 249, 0, .80]), 3), new dojo.Color([151, 249, 0, 0.45]));
            var polygon = new esri.geometry.Polygon({
                "rings": [
              [-4226661.916056009, 8496372.808143634],
              [-3835304.3312360067, 8731187.359035634],
              [-2269873.991956003, 9005137.668409634],
              [-4304933.433020009, 7635386.121539632],
              [-4304933.433020009, 7674521.880021632],
                    "wkid": 102100
            features.push(new esri.Graphic(polygon, polygonSymbol));
            featureLayerPolygon.applyEdits(features, null, null);
        dojo.ready(init);
    </script>
derekswingley1
Please elaborate on what you've tried and what, specifically, is failing.
HemingZhu
mike, a couple of issues in your function requestPolygon(itemInfo). 1. features is undefined. 2. the attributes of the feature you added to your featureLayerPolygon are missing. Try this:
                "rings": [
                    "wkid": 102100
            var attr = {};
            attr["description"] = your description string;
            attr["title"] = your title string;
            featureLayerPolygon.applyEdits([new esri.Graphic(polygon, polygonSymbol, attr)], null, null);
mikezheng
I want to generate a featurelayer with polygon and add it to map. Actually, i could add it to map thru map.graphics.add(); But i want to use featurelayer.
Thanks.
mikezheng
                "rings": [
                    "wkid": 102100
            var attr = {};
Hi hzhu,
Thanks a lot for your code.
But it still doesn't work.
Thanks again.
HemingZhu
Hi hzhu,
Thanks again.
Mike, since i don't have your complete code, i modified the ESRI sample (http://help.arcgis.com/en/webapi/javascript/arcgis/demos/fl/fl_featureCollection.html)  a little bit to include your posted code. It worked. Maybe there are something else in your code (webmap?) that you need look into.
mikezheng
Hi hzhu,
Thank you very very much for your code. it work now. 🙂
Another question, after i added that featurelayer, how could i retrieve it? i don't know which object should be used, "map" or "esri". i mean i want to get that polygon in a event.
thanks again,
Mike
HemingZhu
Hi hzhu,
thanks again,
Mike
Mike, you already have an event handler in your code:
//evt.graphic will be the polygon feature you clicked at.
//evt.graphic.geometry will the polygon itself you clicked at
Besides that, you can look at the featurelayer library and pick up any event that fits your need: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/featurelayer.htm
mikezheng
Thanks. Actually, i already defined it named "featurelayer". it is my need. 🙂
Thanks a lot.
