The Load() event of the Search widget is nerver called?
1958
05-09-2017 11:22 AM
MartinOuellet2
This piece of code (taken from the 4.3 doc #) is never called
searchWidget.on("load", function (evt) {
   console.log("Search widget has loaded!");
any thoughts?
PhilLarkin1
That is interesting.
I tried wrapping the widget creation, event registration in a timeout. Didn't help:
JS Bin - Collaborative JavaScript Debugging
by Anonymous User
Not applicable
Hello martin,
There is an event which is not loading properly. If still the console log is required, fire the statement without on load event. It will work. what I mean to say is
original text-
searchWidget.on("load", function (evt) {    console.log("Search widget has loaded!"); });
Replace it with-
Without event
KellyHutchins
Esri Notable Contributor
Looks like a bug with the Search widget. We'll get it fixed for the next release of the API.
KristianEkenes
The load event never actually existed on the Search widget. This was a documentation error that will be removed at 4.4.
