TextSymbol not appearing in Internet Explorer?
11384
17
08-06-2014 07:47 AM
KC
Maybe it's just me, but since I've contacted ESRI and they can't figure it out either, I'm throwing this out there in case someone has experienced this and can shed some light on the subject:
With some TextSymbol labeling code I am working on, I have discovered that when I view my work in Internet Explorer (11), the labels do not show up.  They show up in Chrome and Firefox.  I also see the same thing when I use the Points for labeling sample:  When I copy and paste the source code for this sample into a HTML page and view it on my web server, the labeling does not appear for me in just IE.  However, when I view ESRI's live sample in IE, the labels DO show up.  My coworker also experiences the same when viewing these on her computer in IE.
After contacting ESRI Technical Support, we tried looking at the IE Developer Console etc, but no errors were reported when running the page.  Also even though I do not see the TextSymbol labels show up when I view my copy of the Points for labeling sample, the ESRI tech had no problem viewing the labels viewing the same page hosted on my external web server.  Because they were not able to reproduce the issue on their end, I couldn't get an incident ticket created.
So, anybody got an idea what may be going on given the above?  Is it some kind of strange security setting in my LAN that enables us to view TextSymbols in IE on ESRI's site but not on the same code served out of my web server?  Something else to try to help troubleshoot this?
Thank you for your time,
Kirstin
RobertScheitlin__GISP
Kirstin,
  You can force your html page to not use Compatability mode by adding this to the header in the HTML code:
<meta http-equiv="X-UA-Compatible" content="IE=edge">
TimWitt2
Hey Kristin,
can you share your application? This would make it easier to investigate.
Tim
KC
Hi Tim,
My application isn't ready for public consumption, but the same issue happens for me when using ESRI's Points for labeling sample.  Here's my copy of the same thing, but I'm guessing you will not have any issues viewing the generated TextSymbol labels in IE since ESRI reported they didn't have any problems with that page (but I still have IE issues when viewing the page within my LAN, I guess...)
Kirstin,
   Yep your link worked for me in IE11 too.
Tim,
   You are exactly right. You can tell from the zoom in/out (being square and not rounded) that the page is running in compatibility mode.
Kirstin,
You need to check your IE "Compatibility View Settings" and make sure you uncheck "Display intranet sites in Compatibility View"
KC
Even with the "Display intranet sites in Compatibility View" unchecked, my zoom +/- buttons are still not rounded...
Kirstin,
   Is your website url listed in the Compatibility View settings dialog like I posted earlier?
Kirstin,
KC
Robert,
That line works for me and my IE9 coworker in the ESRI sample and the code I was working on.  This probably works best for us (since it would probably be a hassle to get all of my internal users to change their compatibility settings for the ubiquitous IE browser we all have on our machines here)
Thank you!
Kirstin,
   I took the esri sample Points for labeling | ArcGIS API for JavaScript‌ and deployed it on my IIS development machine and opened it in IE 11 and I had no issue seeing the label. I would start by going to "Internet Options" > Advanced tab and click the "Reset" button under "Reset Internet Explorer settings" as a test to see if something is just out of wack with your IE setup.
