Tax Parcel Viewer - How to ShowProgressIndicator when Panning Map/Parcels Loading?
1057
01-24-2014 04:21 AM
DarrinBaldinelli
Hi all,
To anyone who is familiar with the Tax Parcel Viewer (http://www.arcgis.com/home/item.html?id=23cc5b90b78d45e0bd51ede193328568), our users are requesting we have a progress indicator for when the user is panning the map and image data is still loading, and I am not sure where to start. Currently, when the data is loading, the map just shows the background color of the basemap, and the concern is that because sometimes it takes a few seconds to load, unless the user knows it is loading, they will leave the page.
I realize it might be difficult to propose a solution without seeing our code (I can provide links to code , but it is the standard Tax Parcel Viewer 10.2 application, and of course we are using our own locally-hosted map services with the application).
You can replicate the issue by doing the following:
1. Go to http://www.lcounty.com/taxparcelviewer/
2. Quickly zoom in to any area of the county (say the middle of Newark township, for example). You will see roads, but the map will take a few seconds to load all the text. The goal is for there to be a progress indicator while this loading is taking place (the application's ShowProgressIndicator function in utils.js would be fine for now). I'm just having a hard time finding the place in the TPV's code where I would call this function so it would do what we need.
Please let me know if you have any ideas regarding this. Help is much appreciated.
JimWestman
There is a an existing indicator.
when you start your action do this...
dojo.byId("imgSearchLoader").style.display = "block";
when the action is done invoke this...
dojo.byId("imgSearchLoader").style.display = "none";
For panning, you might need to wire a function for onPanBegin and and onPanEnd or the equivalent events, see the JSAPI Map-Events.
Jim
