TakeScreenShot arcgis javascript 4.13 - Black Background
3296
11-25-2019 09:16 PM
DavidDoyle
I have a base layer that is the outlines of blocks. DCDB.
there is no fill just outline.
from service:
Symbol:
Style: esriSFSSolid
Color: [0, 0, 0, 0]
Outline:Style: esriSLSSolid
Color: [156, 156, 156, 127]
If i use view.takeScreenshot()   i get a black background. which doesnt match what i see on the screen, which is a white background.
ive also tried a sat image as the base layer. and if i back that visible = false, on the view i get my parcel outlines with a white background. If i take a snapshot  i get the same black background.
My issue is sometimes we just want a snapshot of the parcel outlines....not with an image on any background.
Ive attached a screenshot of my view and  the image i get from takesnapshot.
RobertScheitlin__GISP
David,
   A Jpeg output always has to have a background and because you do not have a background visible the default back color is used. If you screenshot with a PNG format then it does allow for a transparent background and this would be idea for your situation.
David,
DavidDoyle
Thank you so much Robert.
I feel rather stupid as I knew about the png allowing transpernt backgrounds.  but I tried everything but changing the format.
As soon as I did that it worked perfect.
 As a new esri user  these forums are a life saver.
Thanks again.
