Table Summary
3741
5
09-09-2013 10:28 AM
BillShockley
I am working with the example 'Query with Feature Layer' and I am trying to get some totals from the table.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
  <title>Page through records</title>
  <style>
    html, body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
      overflow: hidden;
      font-family: "Roboto Condensed", sans-serif;
      font-size: 0.90em;
      margin: 0 auto;
      width: 750px;
    #grid {
      height: 336px;
      width: 100%;
    .field-name {
      width: 200px;
      font-size: .80em;
      font-weight: normal;
    .field-magnitude {
      width: 50px;
      font-size: .80em;
    .field-deaths {
      width: 70px;
      font-size: .80em;
    .field-date {
      width: 70px;
      font-size: .80em;
    #grid .dgrid-row-odd {
      background: #F2F5F9;
  </style>
  <script src="http://js.arcgis.com/3.6/">
  </script>
  <script>
    var featureLayer, pageInfo, grid;
    require([
      "esri/layers/FeatureLayer", "esri/tasks/query", "esri/TimeExtent",
      "dojo/number", "dojo/date/locale", "dojo/dom","dojo/on",
      "dojo/_base/array", "dojo/store/Memory",
      "dgrid/OnDemandGrid", "dojo/domReady!"
    ], function(
      FeatureLayer, Query, TimeExtent,
      number, locale, dom, on,
      arrayUtils, Memory,
      OnDemandGrid
      // create a dgrid
      var sortAttr = [{
        attribute: "magnitude",
        descending: true
      grid = new OnDemandGrid({
        store: Memory({
          idProperty: "name"
        columns:{
          magnitude: {
            label: "Magnitude",
            formatter: formatRound
          deaths: "Deaths",
          date:{
            label: "Date",
            formatter: formatDate
        sort: sortAttr
      }, "grid");
      // create a feature layer
      featureLayer = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/0", {
        outFields:["*"]
      // get object IDs from the table (feature layer)
      featureLayer.on("load", function () {
        // create the query to fetch object IDs for earthquakes that have a magnitude greater than 6.0
        // that occurred after January 1st 2007
        var query = new Query();
        query.where = "Magnitude > 6.0 AND Num_Deaths >= 1";
        query.timeExtent = new TimeExtent(new Date("01/01/2007 UTC"));
        featureLayer.queryIds(query, function (objectIds) {
          fetchRecords(objectIds);
      // click listeners for prev/next page buttons
      on(dom.byId("prev"), "click", function() {
        queryRecordsByPage(pageInfo.currentPage - 1);
      on(dom.byId("next"), "click", function() {
        queryRecordsByPage(pageInfo.currentPage + 1);
      // formatting function for numbers
      function formatRound(value) {
        return number.round(value, 2);
      // formatting function for dates
      function formatDate(value) {
        var inputDate = new Date(value);
        return locale.format(inputDate, {
          selector: "date",
          datePattern: "MMMM d, y"
      function fetchRecords(objectIds) {
        if (objectIds.length > 0) {
          updatePageInformation(objectIds);
          queryRecordsByPage(1);
        } else {
          grid.showMessage("No matching records");
          grid.setStore(null);
      function updatePageInformation(objectIds, page) {
        pageInfo = {
          objectIds: objectIds,
          totalRecords: objectIds.length,
          totalPages: Math.ceil(objectIds.length / 15),
          currentPage: page || 0,
          recordsPerPage: 15
        dom.byId("pageInfo").innerHTML = pageInfo.currentPage + "/" + pageInfo.totalPages;
        dom.byId("recordsInfo").innerHTML = pageInfo.totalRecords;
        if (pageInfo.currentPage > pageInfo.totalPages) {
      function queryRecordsByPage(pageNumber) {
        // check if the page number is valid
        if (pageNumber < 1 || pageNumber > pageInfo.totalPages) {
          return;
        //grid.showMessage("Fetching records...");
        var begin = pageInfo.recordsPerPage * (pageNumber - 1);
        var end = begin + pageInfo.recordsPerPage;
        // create the query
        query.objectIds = pageInfo.objectIds.slice(begin, end);
        query.outFields = ["*"];
        // Query for the records with the given object IDs and populate the grid
        featureLayer.queryFeatures(query, function (featureSet) {
          updateGrid(featureSet, pageNumber);
      function updateGrid(featureSet, pageNumber) {
        var data = arrayUtils.map(featureSet.features, function (entry, i) {
          return {
            magnitude: entry.attributes.Magnitude,
            deaths: entry.attributes.Num_Deaths,
            date: entry.attributes.Date_
        grid.store.setData(data);
        grid.refresh();
        // update application state
        pageInfo.currentPage = pageNumber;
  </script>
</head>
<body>
<p>
  Total records:
  <span id="recordsInfo">0</span>
  <button id="prev">Prev Page</button>
    <span id="pageInfo"></span>
  <button id="next">Next Page</button>
</p>
<!-- dgrid will be created in this div -->
<div id="grid"></div>
</body>
</html>
If I understand the code correctly, this section gives the total number or records at the top of the table:
        pageInfo = {
          recordsPerPage: 15
The example gives a table with earthquake name and Magnitute.  At the top it list the total records: 29.  Now this is where I need some help.  What would I need to add to the code to illustrate a list of how many of each there are.  I need a summary on the name.
Example:
JAPAN: HONSHU: W COAST : 2
KYRGYZSTAN: NURA: 1
HONDURAS : 1
...etc.
Does this make sense?  Any help is much appreciated.
JasonZou
Make use of query.outStatistics. Here is a sample. In order to use this feature, the layer or the table has to Support Statistics when published.
require([
  "esri/tasks/Query", "esri/tasks/StatisticDefinition", ...
], function(Query, StatisticDefinition, ... ) {
  var statisticDefinition = new StatisticDefinition();
  statisticDefinition.statisticType = "count";
  statisticDefinition.onStatisticField = "Name";
  statisticDefinition.outStatisticFieldName = "Total";
  query.outStatistics = [statisticDefinition];
BillShockley
require([
This seems to be what i am looking for.  I am not much of a programmer...would you be able to help me out with the code for this or point me in the direction as to where this would go in the code.?
Thanks in advance.
JasonZou
Below is the revised portion for query. You will need to change other portion accordingly with the new change, mainly the change of the fields returned from the query, and how to present them in the data grid.
        statisticDefinition.onStatisticField = "name";
        statisticDefinition.outStatisticFieldName = "total";
BillShockley
Jason,
I appreciate your help on this...but that didn't quite do it.  When I add this:
it pretty much kills the table.  I added the require at the beginning.  Sorry to trouble you on this...I'm still learning.
thanks,
JasonZou
Bill, the code provided just shows you the idea how to use query.outStatistics to get the field statistics, but it won't work with the feature layer in your code. As I mentioned earlier, to use query.outStatistics, the feature layer or the table has to support Statistics. The layer used in your example does not support it. Compare it with this layer, and looking for Supports Statistics:, you will know what I mean.
It'd be helpful to understand the sample.
