Synchronizing map and data grid interaction?
5406
11
10-01-2015 01:45 PM
DavidChrest
This great article by esri's ArcGIS JS API guru, Kelly Hutchins: Synchronizing map and data grid interaction with the ArcGIS API for JavaScript | ArcGIS Blog, explains how to:
  • Hover over map graphics and highlight the associated row.
  • Hover over rows in the table and highlight the associated graphic.
Using the dojox DataGrid.
I am using the dgrid/OnDemandGrid and would really love to know how to this exact thing with the dgrid.
Thank you so much.
David
TracySchloss
Honored Contributor
I have a hard time keeping track of the 2.  I lose track of what is getting used in the various tutorials.
DavidChrest
Thanks to this earlier post https://community.esri.com/thread/92368 from someone who was trying to do exactly what I was going for, I found a nice solution to syncing my dgrid and corresponding data. Code in the above post from Esri's @Johnathan Uihlein was the ticket.
I select a set of points by buffer or drawing tool, results in a dgrid, then want to click a dgrid row and see that point highlighted in my map. Here is the code that makes it work after selection.
gridMydGrid.on(".field-OBJECTID:click", selectPoint);
  function selectPoint(e) {
  // select the feature
  var fl = map.getLayer("FLName");
  var features = fl.getSelectedFeatures();
  var symbol = fl.getSelectionSymbol();
  var id = parseInt(e.target.innerHTML);
  var selectedGraphic;
  array.forEach(features, function (feature) {
  if (feature.attributes.OBJECTID === id) {
  selectedGraphic = feature;
  feature.setSymbol(symbol);
  var mySymbol = new SimpleMarkerSymbol().setOutline(null).setColor("#0000FE").setSize("20");
  selectedGraphic.setSymbol(mySymbol);
  var mp1A = selectedGraphic.geometry;
  map.centerAndZoom(mp1A, 16);
