Sync two maps
5437
06-05-2013 02:37 AM
OrenGal
I have two maps. I want map2 to pan while map1 is panning
map2 is refreshing only when I finish the pan.
dojo.connect(map1, "onPan", onPan);
function onPan(extent, delta) {
map2.setExtent(extent);
Oren
BenFousek
Set the following on app load:
esriConfig.defaults.map.panDuration = 0;
OrenGal
Made sample
please look at the delay while panning
http://jsfiddle.net/orengal/d7Ycr/1/
BenFousek
OrenGal
So simple!
Thanks!
fixed:
http://jsfiddle.net/orengal/d7Ycr/5/
JackFairfield
Thanks a bunch.  I was stuck on this for a while.  I had a bug that was producing a sort of feedback loop.  I think it was trying to process two animations at once and was causing it to freak out.  Setting to 0 ensures the event post processing is complete before the next event post processing begins.
