symbolPreview not working
4541
8
04-16-2018 11:38 AM
Blanca_FlorHabana_Matamoros
I try to add the symbols obtained from the map layers in a div, I'm using symbolPreview does not give any errors but does not add the symbols in the div.
What is wrong?
var symbol = drawingInfo.renderer; symbolPreview.renderPreviewHTML(symbol, { node: document.getElementById(nombreImg), size: 12, opacity: 1 });
Tags (3)
RobertScheitlin__GISP
Blanca,
   So if you are using esriRequest to get the drawingInfo then it is just a json string and not an actual esri renderer or symbol class. So you would use:
require(["esri/symbols/SimpleFillSymbol"], function(SimpleFillSymbol) {
  var sym = SimpleFillSymbol.fromJSON(‍drawingInfo.renderer.symbol);‍
  symbolPreview.renderPreviewHTML(sym, {
    node: document.getElementById("symDiv"),
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Blanca,
   You are sending a Renderer class into the symbolPreview. The symbolPreview class is expecting a Symbol class not a Renderer.
// symbol from SimpleRenderer;
var symbol = layer.renderer.symbol.clone();
  node: document.getElementById("preview"),
I already sent a symbol but it does the same.
var symbol = drawingInfo.renderer.symbol.clone();
console.log("dentro del symbol", symbol);
var s = new Symbol({
type: symbol.type,
color: symbol.color,
outline: {
color: symbol.outline.color,
type: symbol.outline.type,
width: symbol.outline.width
node: document.getElementById(div),
I sent the symbol of this way but I don't sure if that is correct
Blanca,
   Here is a full working sample, to help you understand better.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Legend widget - 4.6</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #symDiv {
      position: absolute;
      z-index: 99;
      top: 10px;
      right: 10px;
      width: 50px;
      height: 50px;
      background-color: white;
  </style>
  <script src="https://js.arcgis.com/4.6/"></script>
  <script>
    require([
        "esri/views/MapView",
        "esri/widgets/Legend",
        "esri/WebMap",
        "esri/symbols/support/symbolPreview",
        "dojo/domReady!"
      function(
        MapView, Legend, WebMap, symbolPreview
        var webmap = new WebMap({
          portalItem: { // autocasts as new PortalItem()
        var view = new MapView({
          container: "viewDiv",
          map: webmap
        view.when(function() {
          // get the first layer in the collection of operational layers in the WebMap
          // when the resources in the MapView have loaded.
          var featureLayer = webmap.layers.getItemAt(0);
          var legend = new Legend({
            view: view,
            layerInfos: [{
              layer: featureLayer,
              title: "NY Educational Attainment"
          // Add widget to the bottom right corner of the view
          view.ui.add(legend, "bottom-right");
          var symbol = featureLayer.renderer.uniqueValueInfos[3].symbol.clone();
  </script>
</head>
<body class="calcite">
  <div id="viewDiv"></div>
  <div id="symDiv"></div>
</body>
</html>
I have a doubt, in your example you have the next line :
But, in the layers of my application the renderer is null and I get the
information with esriRequest and the renderer have this information
and when I try to add clone function I get the error "clone is not a
function"
Sorry if I ask a lot but I don't have experience working with the api
2018-04-16 14:48 GMT-05:00 Robert Scheitlin, GISP <[email protected]>:
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: symbolPreview not working
reply from Robert Scheitlin, GISP
<https://community.esri.com/people/rscheitlin?et=watches.email.thread> in *ArcGIS
API for JavaScript* - View the full discussion
<https://community.esri.com/message/764423-re-symbolpreview-not-working?commentID=764423&et=watches.email.thread#comment-764423>
And thanks so much for yout quick response and help
2018-04-16 16:55 GMT-05:00 Blanca Flor Habana Matamoros <
[email protected]>:
function"
>> in ArcGIS API for JavaScript - View the full discussion
Blanca,
Thaks so much by your help
