Switching basemaps requires login
2394
12-16-2016 11:34 AM
AdamSwank
As of today, when a user my app switches the basemap to streets-vector, a login screen pops up.  Is the streets-vector basemap no longer free to use?
Tags (1)
KenBuja
MVP Esteemed Contributor
That doesn't happen in the BasemapToggle sample using that vector basemap
AdamSwank
So, I just played around with that and you are right that it does work if you add streets-vector in.  But it is using the 4.1 api and I am using the 4.0 api. If you switch the sample to use the 4.0 api it has the same problem.
Is th 4.0 api still supported?
KenBuja
odoe‌ may have some insight on that.
