Switching Basemaps Programmatically
11216
14
06-06-2014 07:33 AM
ChrisHavel
I am trying to change basemaps without the BaseMap widget.
I can accomplish this BUT I have two buttons and I only want ONE..
I am trying to invision how to do this with one button....
1. I should be able to use a toggler of some sort
2. if not I can use an If Then statement or a Case as seen below BUT would need to fidn out how to determine the name of the current basemap that is being displayed..
    map = new esri.Map("map", {
       basemap: "topo",
If I am looking at the code above....
1. How do I test for the basemap? Return to a variable and then I can use in the Case below.
I tried this and got 'undefined'
 var layer = map.getLayer('basemap');
 var layerUrl;
 switch(basemap){
    case 'topo':
            layerUrl = 'https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer';
            break;
    case 'imagery':
            layerUrl = 'https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer';
            break;
 var basemap = new esri.layers.ArcGISTiledMapServiceLayer(layerUrl,{id:'basemap'});
 map.addLayer(basemap,0);
alert(layer);
WORKING CODE BUT TWO BUTTONS
 <div dojotype='dijit.layout.ContentPane' region='top' style='height:20px;'>
      <input type='button' value='Topo' onclick='switchMap("topo");'/>
      <input type='button' value ='Imagery' onclick='switchMap("imagery");'/>
 </div>
        map = new esri.Map("map",{
          extent:initExtent
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer",{id:'basemap'});
        map.addLayer(basemap);
      function switchMap(basemap){
        //remove the existing basemap layer
        map.removeLayer(layer);
        var layerUrl;
        switch(basemap){
          case 'topo':
            break;
          case 'imagery':
            break;
ChristianSailer2
Thank you this has helped to find the ids names! Great!
//But when I'm using the default-widget.
var basemapGallery = new BasemapGallery({
  showArcGISBasemaps: true,
  map: map
  }, "basemapGallery");
  basemapGallery.startup();
//I cannot add
  basemapGallery.remove("basemap_0");
//to remove a basemap. It return Null!
//I think basemap_0 is not yet recognized after the startup()
//Do you have a solution for that?
//Thank you
KenBuja
MVP Esteemed Contributor
I would suggest starting a new discussion on this. It would help get the attention of the Javascript API experts at Esri.
ChristianSailer2
AndrewPratt
Take a look at my demo site. I just the basemap toggle and then just applied CSS to override the defaults.
Javascript
var toggle = new BasemapToggle({
  map: app.map,
  basemap: "hybrid"
   }, "BasemapToggle");
   toggle.startup();
CSS
#BasemapToggle {
      position: absolute;
      top: 20px;
      right: 20px;
      z-index: 50;
  .BasemapToggle .basemapImage {
     height: 0;
     overflow: hidden;
     width: 0px;
  .BasemapToggle .basemapTitle {
  width: 80px;
Project Map Viewer
YungKaiChin
Just want to add to Andrew Pratt‌'s code.
You could add an event listener to the toggle and do switch there between 2 or more base layer.
Example:
toggler.on("toggle", changeNextBasemap);
function changeNextBasemap(event){
     switch(event.currentBasemap){
          case 1:
               toggle.basemap = "whatever";
               break;
          case 2:
          case 3:
          case 4:
