switch Dgrid with HTML to return results
8146
16
10-17-2015 11:28 AM
jaykapalczynski
Honored Contributor
I am using a dgrid to reurn my results from a query.  I am looking for a solution to do this in strictly HTML and cant find a solution.  Does anyone have a very basic example.
This is what I am doing right now.
<div data-dojo-type="dijit/layout/ContentPane" id="ScrollGridContainer" title="Scroll Grids">
   <div class="gridclassheader">Unique Species Observations:</div>
   <div id=text style="font-size:small; line-height: 40%; text-align:center; padding:0px;">.</div>
   <div id="gridNoColumnSets55" class="gridclassGrid"></div>
</div>
I ATTACHED the JavaScript as it was not formatting correctly when I tried to put in the post....
Just looking for an easy way to grab the result of the query and use HTML to format the returned results in my app.  I am using printThis to allow the user to print the results of the query and map but the dgrid does not hold up...which is why I am trying to return the results to html which I can then format via CSS......
Can anyone help?
RobertScheitlin__GISP
Jay,
  There is no reason (that I am aware of) to map thought the results and create a Memory store if you are not using a dGrid.
Here is the function updated with your function name and input parameter name.
        function updateGrid3(featureSet) {
          domConstruct.empty("info");
          var table = domConstruct.toDom('<table style="width:100%"></table>');
          domConstruct.place(table, "info");
          var resultItems = [];
          var resultCount = featureSet.features.length;
          var tableHeaderRow, tableHeader, tableRow, tableCol, tableBody;
          for (var i = 0; i < resultCount; i++) {
            if(i === 0){
              tableHeaderRow = domConstruct.create("tr");
              domConstruct.place(tableHeaderRow, table);
              tableBody = domConstruct.create("tbody");
              domConstruct.place(tableBody, table);
            tableRow = domConstruct.create("tr");
            domConstruct.place(tableRow, tableBody);
            var featureAttributes = featureSet.features.attributes;
            for (var attr in featureAttributes) {
              if(i === 0){
                tableHeader = domConstruct.toDom('<th>' + attr + '</th>');
                domConstruct.place(tableHeader, tableHeaderRow);
              tableCol = domConstruct.toDom('<td>' + featureAttributes[attr] + '</td>');
              domConstruct.place(tableCol, tableRow);
            domConstruct.place(tableRow, table);
jaykapalczynski
Honored Contributor
I can convert the results to json which I think is easier to then display in html but have yet to find a dynamic way to represent the data in html
  var data = arrayUtils.map(featureSet.features, function (entry, i) {
   return {
  ObsID: entry.attributes.ObsID,
  SppBova: entry.attributes.SppBova,
  COMMON_NAME: entry.attributes.COMMON_NAME,
  GENUS: entry.attributes.GENUS,
  SPECIES: entry.attributes.SPECIES,
  Tier: entry.attributes.Tier,
  FedStatus: entry.attributes.FedStatus,
  TaxaGrp: entry.attributes.TaxaGrp,
  // If you use a store...
  dataStore = new Memory({
  "data": data,
  "idProperty": "id"
var myJsonString = JSON.stringify(data);
var json_obj = JSON.parse(myJsonString);
alert(JSON.stringify(json_obj));
jaykapalczynski
Honored Contributor
I took the array variable "data" and tried to get it into a table as seen below.  I get the correct number of rows returning but NO data....just "undefined"  Any thoughts as to why?
HTML
<div id="id01"></div>
JAVASCRIPT
    var i;
    var out = "<table>";
    for(i = 0; i < data.length; i++) {
        out += "<tr><td >" +
        arr.OBJECTID +
        "</td><td>" +
        arr.ObsID +
        "</td><td>" +
        arr.SppBova +
        "</td><td>" +
        arr.COMMON_NAME +
        "</td><td>" +
        arr.GENUS +
        "</td><td>" +
        arr.SPECIES +
        "</td><td>" +
        arr.Tier +
        "</td><td>" +
        arr.FedStatus +
        "</td><td>" +
        arr.TaxaGrp +
        "</td></tr>";
    out += "</table>";
    document.getElementById("id01").innerHTML = out;
jaykapalczynski
Honored Contributor
think I got something....I was using the JSON string instead of the original array string "data" I changed to that and I am not getting a result...
added this before the For Loop
var arr = (data);
Jay,
Here is a full working sample that takes queryTask results and builds a HTML Table from the results:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Query State Info without Map</title>
    <script src="http://js.arcgis.com/3.14/"></script>
    <style>
      table, th, td {
        border: 1px solid black;
        border-collapse: collapse;
      th, td {
        padding: 8px;
      th {
        background-color: #eee;
    </style>
    <script>
      require([
        "dojo/dom",
        "dojo/dom-construct",
        "dojo/on",
        "esri/tasks/query",
        "esri/tasks/QueryTask",
        "dojo/domReady!"
      ], function (dom, domConstruct, on, Query, QueryTask) {
        var queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5");
        var query = new Query();
        query.returnGeometry = false;
        query.outFields = [
          "SQMI", "STATE_NAME", "STATE_FIPS", "SUB_REGION", "STATE_ABBR",
          "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI", "HOUSEHOLDS",
          "MALES", "FEMALES", "WHITE", "BLACK", "AMERI_ES", "ASIAN", "OTHER",
          "HISPANIC", "AGE_UNDER5", "AGE_5_17", "AGE_18_21", "AGE_22_29",
          "AGE_30_39", "AGE_40_49", "AGE_50_64", "AGE_65_UP"
        on(dom.byId("execute"), "click", execute);
        function execute () {
          query.text = dom.byId("stateName").value;
          queryTask.execute(query, showResults);
        function showResults (results) {
          var resultCount = results.features.length;
            if(i === 0){
            var featureAttributes = results.features.attributes;
              if(i === 0){
    </script>
  </head>
  <body>
    US state name :
    <input type="text" id="stateName" value="California">
    <input id="execute" type="button" value="Get Details">
    <br />
    <br />
    <div id="info"></div>
  </body>
</html>
jaykapalczynski
Honored Contributor
Thanks for your reply Robert,...very much appreciated....but having issues because I think I am going about this slightly different
AS you can see from my code (attached) I am grabbing results from a Buffer Geometry.....then was sending those to a grid....little bit different from your example...
I hang up on your code here:  var featureAttributes = results.features.attributes;
Is there a way to bring in this array or json string into your code?  In my txt file attached I am trying to get the json object in....if I use the array "Data" it shows results but not formatted in any fashion.
thoughts?  really confused.
jaykapalczynski
Honored Contributor
Alright I added the below and I was able to return results....but the formatting is all crazy....I assume that I can modify this with CSS?
  var query3 = new Query();
  query3.geometry = bufferGeometry;
  // Select the Points within the Buffer and show them
  featureLayerVAFWIS.selectFeatures(query3, FeatureLayer.SELECTION_NEW, function(results){
  // Query for the records with the given object IDs and populate the grid
  featureLayerVAFWIS.queryFeatures(query3, function (featureSet) {
updateGrid3(featureSet);
showResults(featureSet);
Jay,
   Sure I provided css styling in my example.
Jay,
            if(i === 0){
              if(i === 0){
jaykapalczynski
Honored Contributor
Last three questions.....more for the understanding of where or not its possible....any thoughts would be appreciated....what ever you can help with I would be appreciative but understand either way...
Can I select a record and have it highlight its feature in the map?
Is there the ability to sort?
Can I specify the widths of each field?
THANK you for your help...its greatly appreciated.
