Survey123 form in iFrame format changes
1805
6
11-28-2023 10:00 AM
kapalczynski
I can embed my Form onto an Iframe BUT the Format is not recognized and the collapsed sections are not active to make them un-collapsed...
Is this a bug or is there something I can do to make inherit the forms functionality of columns and collapsible sections????
Please help
Survey123
In the iFrame of a simple html webpage
jcarlson
It looks like you're using a grid style? The web version of S123 won't display grids properly. Try republishing the form with a different style and see if that fixes it, maybe.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
kapalczynski
what about the collapsible sections... these will not work either? or maybe those arent working as well due to the grids?
jcarlson
They should be fine, we use collapsible sections in our web forms a lot. But I'm wondering if the incompatible style option is interacting with it somehow.
- Josh Carlson
Kendall County GIS
kapalczynski
Why is this incompatible?  Leave it to ESRI to half bake an idea and stop short...
jcarlson
The grid style is meant for mobile devices, so there must be some Survey123 app-related setting that simply doesn't work in a browser context.
- Josh Carlson
Kendall County GIS
kapalczynski
OK I published a very simple form with collapsed group and it seems to work.... sadly any formatting grid style never was thought through
