I am having a hard time setting up the subLayers of a dynamicMap Service layer to display as a checkbox list, so that the sublayers can be turned on or off by the user.
var map, layer, legendLayers = [];
function init() { map = new esri.Map("map", { zoom: 1 }); var basemapUrl = "http://--------------------------"; var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl); layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://---------------------------",{id:'County'}); legendLayers.push({layer:layer,title:"Berkeley County"}); //add the legend dojo.connect(map,'onLayersAddResult',function(results){ var legend = new esri.dijit.Legend({ map:map, layerInfos:legendLayers },"legendDiv"); legend.startup(); }); map.addLayers([basemap,layer]); dojo.connect(map,'onLayersAddResult',function(results){ //add check boxes dojo.forEach(legendLayers,function(layer){ var layerName = layer.subLayerIds; var checkBox = new dijit.form.CheckBox({ name: "checkBox" + layer.subLayerIds, value: layer.subLayerIds, checked: layer.layer.visible, onChange: function(evt) { var clayer = map.getLayer(this.value); clayer.setVisibility(!clayer.visible); this.checked = clayer.visible; } });
//add the check box and label to the toc dojo.place(checkBox.domNode,dojo.byId("toggle"),"after"); var checkLabel = dojo.create('label',{'for':checkBox.name, innerHTML:layerName},checkBox.domNode,"after"); dojo.place("<br />",checkLabel,"after"); }); }); }
