Stupid zoom question
5470
21
04-23-2014 07:20 AM
jaykapalczynski
Honored Contributor
Looking at this example...I can see the locate button widget.
I am not seeing where the Zoom in and Zoom out buttons are being defined !
https://developers.arcgis.com/javascript/jssamples/widget_locate.html
jaykapalczynski
Honored Contributor
trying to get this to work....topo wont even display
Trying to get a home button, Location Button, and the Zoom in and zoom out
http://jsfiddle.net/Jaykapalczynski/WyMzY/11/
JakeSkinner
Esri Esteemed Contributor
Looks like you forgot to call the "dojo/parser" module.
http://jsfiddle.net/WyMzY/12/
LuciHawkins
You need to reference the esri stylesheet and javascript api
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<script src="//js.arcgis.com/3.9/"></script>
Also, you will not get the zoom in/out buttons with slider: false needs to be slider: true
app.map = new esri.Map("map", {
basemap: "topo",
center: [-77.4329, 37.5410],
zoom: 7,
   slider: false,
showAttribution:false,
logo: false
Hope this helps,
Luci
jaykapalczynski
Honored Contributor
So weird I have no idea whats going on...I clear my cache and refreshed my Website...
The parser was added here but still no Zoom in and ZOom out
http://jsfiddle.net/Jaykapalczynski/WyMzY/15/
Below is a snip of my code that should be making this happen, but no go...the Hoem and Locate button are there but no Zoom in Zoom out
        <div id="MapContainer" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
      <div id="map" class="map">
       <div id="HomeButton"></div>
       <div id="LocateButton"></div>
         </div>
     </div>
    <link rel="stylesheet" href="https://js.arcgis.com/3.9/js/esri/css/esri.css">
    <script src="https://js.arcgis.com/3.9/"></script>
       basemap: "topo",
       zoom: 7,
       slider: false,
       showAttribution:true,
       logo: false
      var home = new HomeButton({
        map: app.map
      }, "HomeButton");
      home.startup();
      var geoLocate = new LocateButton({
        map: app.map
      }, "LocateButton");
      geoLocate.startup();
LuciHawkins
Change your code:
basemap: "topo",
zoom: 7,
slider: false,   //this should be slider: true,
logo: false
map: app.map
}, "HomeButton");
home.startup();
map: app.map
}, "LocateButton");
If you change slider: false, to slider: true, you will see the + - zoom buttons
Luci
jaykapalczynski
Honored Contributor
alright its working in the JSFiddle  but for some reason not in my code....this is so simple dont know why I am having an issue.
Will try again...
jaykapalczynski
Honored Contributor
Alright this is VERY weird....I got the example aobve working fine in JS Fiddle.
I pasted all my code from my project into JS Fiddle and it worked.  The exact same code in my project does not display the zoom buttons....wow
The only thing thats different between my project is that JSFiddle requires the below
  • where i define the stylesheets
  • removal of the meta data
  • removal of the <html><head> tags
  • removal of my defined .js page and .css page....of which were copied verbatum into the JS Fiddle.
  • I cleared my cache many times
  • I refreshed the web service many times.
  • Check in 3 different browsers (IE, Chrome, Firefox)
  • No blatant errors in the Chromes debugging Console window
This is driving me nuts....what the heck can be different or causing this
JakeSkinner
If you'd like, post your code as you have it in your project.  Be sure to wrap it in CODE tags.
jaykapalczynski
Honored Contributor
THINKING I MIGHT HAVE GOTTEN IT...I REMOVED A TON OF MY CODE AND STARTED FROM SCRATCH
I am going to add each piece back untill i error out....BRB
jaykapalczynski
Honored Contributor
THINK I MIGHT HAVE GOTTEN IT......BRB
