Stupid zoom question
5344
21
04-23-2014 07:20 AM
jaykapalczynski
Honored Contributor
Looking at this example...I can see the locate button widget.
I am not seeing where the Zoom in and Zoom out buttons are being defined !
https://developers.arcgis.com/javascript/jssamples/widget_locate.html
JakeSkinner
Esri Esteemed Contributor
The navigation zoom in/out will always be created when using the Map class.  For the Overview window, you can control this by specifying the 'attachTo' parameter:
require([   "esri/map", "esri/dijit/OverviewMap", ...  ], function(Map, OverviewMap, ... ) {   var map = new Map( ... );   var overviewMapDijit = new OverviewMap({     map: map,     attachTo: "bottom-right",     color:" #D84E13",     opacity: .40   });   ... });
or by specifying an HTML element:
require([   "esri/map", "esri/dijit/OverviewMap", "dojo/dom", ...  ], function(Map, OverviewMap, dom, ... ) {   var map = new Map( ... );   var globals;   globals.overviewMapDijit = new OverviewMap({     map: map   }, dom.byId('overviewMapDiv'));   ... });
See the following link for more info:
https://developers.arcgis.com/javascript/jsapi/overviewmap-amd.html
MichaelVolz
It looks like it is part of the template used for that sample.  It would be great if an ESRI representative can weigh in on this question.
jaykapalczynski
Honored Contributor
I agree.....then same goes for the Overview Map I think...I want to place the overview map outside the MAP but cant figure out how that location is being defined.
MichaelVolz
Where is this Overview map you are talking about in the Live sample?
JakeSkinner
KenBuja
MVP Esteemed Contributor
That's a part of the Map class. When you initialize it, you have several slider options to set.
jaykapalczynski
Honored Contributor
I am doing this and not getting anything but the Home Button and Locate Button
No zoom in  or zoom out
#map{
     padding:0;
     margin:0;
        width:auto;
 height:auto;
 border:1px solid red;
 border-radius: 20px;
        background-color: #fff;
#HomeButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
#LocateButton {
      position: absolute;
      top: 135px;
      left: 20px;
      z-index: 50;
    <div id="CenterPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
     <div id="MapContainer" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
      <div id="map" class="map">
       <div id="HomeButton"></div>
       <div id="LocateButton"></div>
         </div>
     </div>
  <div id="TabBottomContainer" data-dojo-type="dijit/layout/TabContainer" data-dojo-props="region:'bottom'">
   <div data-dojo-type="dijit/layout/ContentPane" title="Boat Ramps">
    <div id="info2" >
     <div id="grid" class="slate"></div>
    </div>
   </div>
  </div>
    </div>
JakeSkinner
Can you post your JavaScript code, or create a jfsiddle?
KenBuja
Did you initialize your Map with the option "slider: false"?
This example creates a map with no slider or pan arrows.
require([
  "esri/map", ...
], function(Map, ... ) {
  var map = new Map("mapDiv", { slider:false, nav:false });
jaykapalczynski
Honored Contributor
    var app = {};
    app.map = new esri.Map("map", {
       basemap: "topo",
       center: [-77.4329, 37.5410],
       zoom: 7,
       slider: false,
       showAttribution:false,
       logo: false
      var home = new HomeButton({
        map: app.map
      }, "HomeButton");
      home.startup();
      var geoLocate = new LocateButton({
        map: app.map
      }, "LocateButton");
      geoLocate.startup();
