Stream Layer with Web Socket Authentication
739
04-09-2025 07:09 AM
AndrewMurdoch1
Good Day
I have a Stream Layer that works, is there a way to add a Bearer token in the header of the Web Socket when the Stream Layer connects, if so, how?
Here is my current Stream Layer object:
        const websocket = 'ws://blah'
        return new StreamLayer({
            fields: metaLayer ? this._metaFields : fields,
            geometryType: geometry,
            labelingInfo: [layerLabelClass],
            maxReconnectionAttempts: 100,
            maxReconnectionInterval: 10,
            objectIdField: 'objectId',
            renderer: renderSetting,
            timeInfo: {
                trackIdField: "assetSectionId"
            webSocketUrl: `${websocket}`,
            updateInterval: 100
Thanks
UndralBatsukh
Hi there,
You should be able to use StreamLayer.customParameters to add additional params like token.
