Stop a hitTest on layer removal
987
05-20-2021 05:59 AM
JeffreyFrye
Is there a way to turn off a hit test when a layer is removed from a view?
Example: I have a parcel layer that parcels get highlighted on pointer-move event, but when I remove the layer the hitTest continues to run and I receive the connection closed error. So I am assuming that the hitTest is still running and the error is telling me there is no layer to hitTest.
JohnGrayson
Esri Alum
Hard to tell what is going on from the description alone; do you have a very simple CodePen showing the issue?  Hopefully being able to experience the issue will allow the community to suggest solutions or workarounds.
