Spatial Reference changes after adding OpenStreetMap layer from 4326 to 102100
4273
06-11-2016 09:47 AM
ArminPourbeik
I'm using a featureLayer, I want to use OSM as a base map, after adding osm layer my map spatial reference changes from 4326 to 102100 (web Mercator), even if I set my osm layer spatial reference to 4326, how can I fix this problem?
thanks;
function startup() {
    var sr = new esri.SpatialReference({wkid: 4326});
    var startextent = new esri.geometry.Extent(
        50.9484,
        35.9424,
        52.0264,
        36.4271,
        sr
    lyr_branches = new esri.layers.FeatureLayer('http://localhost:6080/arcgis/rest/services/DayBank/MapServer/7', {
        mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
        outFields: ['*']
    map = new esri.Map('map', {
        extent: startextent,
        center: [51.420598, 35.721900],
        zoom: 11,
        fadeOnZoom: true,
        minZoom: 10,
        spatialReference: new esri.SpatialReference({wkid: 4326})
    osm = new esri.layers.OpenStreetMapLayer({
        initialٍExtent: startextent,
            wkid: 4326
    var selectionSymbol = new esri.symbol.SimpleMarkerSymbol();
    selectionSymbol.setSize(20);
    selectionSymbol.setColor(new dojo.Color([255, 0, 0, 0.5]));
    lyr_branches.setSelectionSymbol(selectionSymbol);
//    map.addLayer(osm);
    map.addLayer(lyr_branches);
    var featureTable = new esri.dijit.FeatureTable({
        featureLayer: lyr_branches,
        map: map,
        editable: false,
        showGridHeader: false,
        showGridMenu: false,
        showDataTypes: false,
        outFields: ["PostalCode", "Telephone", "Fax", "Address", "Code", "Name"]
    }, 'myTableNode');
    featureTable.startup();
    //create query task
    queryTask = new esri.tasks.QueryTask('http://localhost:6080/arcgis/rest/services/DayBank/MapServer/7');
    cf = new esri.tasks.ClosestFacilityTask('http://localhost:6080/arcgis/rest/services/DayBank/NAServer/Closest%20Facility');
RobertScheitlin__GISP
Armin,
  Almost all esri basemaps are web mercator 102100. So it is normal for the maps spatial reference to change to 102100 after applying an esri basemap.
ArminPourbeik
thanks for your answer Robert,
I'm getting user's current location with HTML5 Geolocation API which gives me coordinates in 4326 Spatial Reference. as I want to use this point as  incidents in closest facility network analysis, I must convert this point's spatial reference to my map and facilitiy points which is 102100, so how can I do that? I tried proj4js but I didn't succeed...
ArminPourbeik
Oh, I just found esri.geometry.lngLatToXY() method.
thanks any way;)
