Some icons are not drawing on buttons
1765
11-12-2014 02:37 PM
KenBuja
MVP Esteemed Contributor
I am adding icons to buttons on a drawing tool using 16 pixel icons from the ArcGIS icon collection supplied by the Developer's Kit (C:\Program Files (x86)\ArcGIS\DeveloperKit10.0\Icons). However, not all of the icons are getting added to the buttons. I've tried using the icon or an imbedded image using a base 64 data URI (converted using this site) but neither works.
I've put an example here, with the polygon and extent buttons not getting their icons added. Any ideas why the two aren't showing up?
JohnGrayson
Esri Alum
Another alternative would be to change your css class names to something unique so they don't conflict with other class names.
JohnGrayson
Esri Alum
You'll also need to specify the image position as you have some conflicts with other css classes that have the same name.
background-position: 0;
JohnGrayson
Esri Alum
KenBuja
Thanks John!
