Snap point to roadway
1386
05-10-2012 06:30 AM
HasnainYusufali
I have an app where a user has to select a point on a roadway.
At lower zoom levels, when the user clicks on the roadway, it looks fine.
However, after zooming in, you can see the point is off and not on the road.
Is there a way where I can snap the point to the roadway, at whatever zoom level the user clicks on the map?
Thanks.
Hasnain
JMcNeil
Is your application an editing app; Is your point layer a feature layer?  If yes then you just need to hold down the control key when dropping your point...this induces snapping.  You can see how it works with this example
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/ed_editing_widget.html
Jay
HasnainYusufali
Jay,
Thanks for the reply. I am not using the editor widget.
All I need from the point is the lat and lon.
I will try to see if I can switch to using the widget.
Hasnain
