Smart Mapping Renderer not obeying basemap property for featurelayer created from points
999
06-07-2017 08:52 AM
DavidChevrier
     I'm creating a feature layer using results from a user's selection by querying an oracle database and using the lat/lon's to create a featurelayer.  I love the smart mapping code, however all I am getting is orange circles.  Changing the basemap property when creating the renderer has no effect.  It works fine if the service is hosted somewhere, but not for feature layers created from feature sets.
Below is the code I'm using to create and render the feature layer.  Any help would be greatly appreciated.
dave
// get data for selected species and create and symbolize feature layer
 function speciesSelected() {
     // selected code and species need for oracle query
      var species = dijit.byId('selectSpecies').attr('displayedValue');
      var svspp = dijit.byId('selectSpecies').attr('value');
      // make sure they were successfully passed
      if ((species == "") || (svspp == "")) {
            return;
       var features = [];
       var oReq = new XMLHttpRequest();
       oReq.onreadystatechange = function () {
             if (oReq.readyState == 4 && oReq.status == 200) {
                   var speciesData = oReq.responseText;
                   var lines = speciesData.split("\n");
                   for (var i = 0; i < (lines.length - 1) ; i++) {
                         var receivedData = lines.split(",");
                         var attr = {};
                         attr["ObjectID"] = i + 1;
                         attr["expNum"] = Number(receivedData[2]);
                         attr["expWT"] = Number(receivedData[3]);
                         attr["SEASON"] = receivedData[4];
                         attr["DATE"] = receivedData[5];
                         attr["YEAR"] = Number(receivedData[6]);
                         var lon = Number(receivedData[0]);
                         var lat = Number(receivedData[1]);
                         var geometry = new Point(lon, lat, new SpatialReference({ wkid: 4326 }));
                         var graphic = new Graphic(geometry);
                               graphic.setAttributes(attr);
                               features.push(graphic);
                         var featureSet = new FeatureSet();
                         featureSet.features = features;
                         featureSet.geometryType = "esriGeometryPoint";
                         var layerDefinition = {
                               "geometryType": "esriGeometryPoint",
                               "objectIdField": "ObjectID",
                               "fields": [{
                                     "name": "ObjectID",
                                     "alias": "ObjectID",
                                     "type": "esriFieldTypeOID"
                                     "name": "expNum",
                                     "alias": "expNum",
                                     "type": "esriFieldTypeDouble"
                                     "name": "expWT",
                                     "alias": "expWT",
                                     "name": "SEASON",
                                     "alias": "SEASON",
                                     "type": "esriFieldTypeString"
                                     "name": "DATE",
                                     "alias": "DATE",
                                     "type": "esriFieldTypeDate"
                                     "name": "YEAR",
                                     "alias": "YEAR",
                                     "type": "esriFieldTypeInteger"
                         var featureCollection = {
                               layerDefinition: layerDefinition,
                               featureSet: featureSet
                         // Remove old layer if one was previously added
                         var speciesFeatureLayerDelete = map.getLayer('Species Layer');
                         if (speciesFeatureLayerDelete) {
                               map.removeLayer(speciesFeatureLayerDelete);
                         speciesFeatureLayer = new FeatureLayer(featureCollection, {
                               "id": "Species Layer",
                               "mode": FeatureLayer.MODE_SNAPSHOT,
                               "infoTemplate": popupTemplate,
                               "outfields": outFields
                        // get max and min lat and lon to set extent for zooming since featurelayer.fullExtent returns null even after loaded
                        var oReq1 = new XMLHttpRequest();
                        oReq1.onreadystatechange = function () {
                              if (oReq1.readyState == 4 && oReq1.status == 200) {
                                    var maxMinLonLatData = oReq1.responseText;
                                    var receivedmmllData = maxMinLonLatData.split(",");
                                    var spatialRef = new SpatialReference({ wkid: 4326 });
                                    var layerExtent = new Extent();
                                    layerExtent.xmax = Number(receivedmmllData[0]);
                                    layerExtent.xmin = Number(receivedmmllData[1]);
                                    layerExtent.ymax = Number(receivedmmllData[2]);
                                    layerExtent.ymin = Number(receivedmmllData[3]);
                                    layerExtent.spatialReference = spatialRef;
                                    map.setExtent(layerExtent);
                                    createRenderer();
                                    map.addLayers([speciesFeatureLayer]);
                        oReq1.open("GET", "retrieveMaxMinLonLat.php?svspp=" + svspp + "&seasonQuery=" + currentSeason, true);
                        oReq1.send();
      oReq.open("GET", "retrieveSpeciesData.php?svspp=" + svspp + "&seasonQuery=" + currentSeason, true);
      oReq.send();
//  create renderer for species feature layer
function createRenderer() {
      smartMapping.createClassedSizeRenderer({
            layer: speciesFeatureLayer,
            field: currentDisplayField,
            basemap: "oceans",
            classificationMethod: currentClassification,
            showOthers: true,
            numClasses: 5
       }).then(function (response) {
             speciesFeatureLayer.setRenderer(response.renderer);
             speciesFeatureLayer.redraw();
             createLegend();
