Slide Bar (two thumbs)
2294
11-14-2016 04:35 PM
EricBianchi1
I am trying to create a slide bar for my map. However, this slide bar needs to show a range between two defined points. So essentially a time interval.
I have these examples to go off on.. Are there any more simple / easy-to-read examples out there?
1) A simple slide bar Simple slide bar
  • I like the simplicity but I need two thumbs
2) Kind of complicated becuase it has the ability to run as a "movie" Hurricanes Two Thumbs
  • I like that it has two thumbs but it is too complex
Thanks!sliders #java scrip api
RobertScheitlin__GISP
EricBianchi1
Site gave me more insight, Thank you! - But if my range slider is for time, is there a way to do a start and end? The regular slide bar works well for time ranges between 0-24. But if one wanted to know 18-07.. then there is a problem.
So I would need something like start and end points for the slider.
hmm..
Eric,
   If you are dealing with time them you will want to use the more complicated sample or look at using
TimeSlider | API Reference | ArcGIS API for JavaScript 3.18
