Sketch widget in Expand breaks React DOM lifecycle (ArcGIS JS API + React)
386
01-30-2026 05:35 PM
Med-Karim-Rouissi
Hello everyone,
I am working with ArcGIS API for JavaScript 4.34 in a React + Vite (TypeScript) project.
I was able without any issue to:
  • initialize a MapView,
  • add a GraphicsLayer,
  • display the Sketch widget directly on the map.
In order to better manage screen space, I then tried to place the Sketch widget inside an Expand widget.
This is where the difficulties started.
Issue encountered
  • Most of the time, the Expand appears empty
  • After several attempts, I managed to make the Sketch widget appear inside the Expand
  • However, this then leads to DOM-related errors on the React side, such as:
Uncaught NotFoundError: Failed to execute 'insertBefore' on 'Node':
The node before which the new node is to be inserted is not a child of this node.
or:
Uncaught DOMException: Node.insertBefore: Child to insert before is not a child of this node
React 32
performWorkUntilDeadline scheduler.development.js:45
react-dom_client.js:9714:50
These errors usually occur:
  • after a React re-render,
  • or during the mount / unmount lifecycle of the Sketch widget,
  • even though the widget initially appears to work correctly inside the Expand.
Technical context
  • React 19.0.0
  • Vite 7.3.0
  • TypeScript
  • ArcGIS JS API 4.34
  • Usage of useEffect, useRef
  • Sketch widget instantiated using the container property
It seems I am facing a conflict between ArcGIS’ imperative DOM management and React’s virtual DOM, especially when the widget is hosted inside an Expand.
Question
Is there:
  • an officially recommended Esri pattern to properly integrate the Sketch widget inside an Expand in a React environment?
  • a known limitation or documented constraint regarding Expand + React?
  • a best practice to avoid these insertBefore errors in this specific scenario?
Here is the relevant code:
// Widget Sketch
useEffect(() => {
  const view = viewRef.current;
  const panel = stylerPanelRef.current;
  const layer = sketchLayerRef.current;
  if (!view || !panel || !layer) return;
  // créer le container Sketch
  const sketchContainer = document.createElement("div");
  sketchContainer.className =
    "w-full h-auto border border-slate-300 dark:border-slate-700 rounded-md mb-2";
  // point d’ancrage STABLE géré par React (le bouton)
  const clearButton = panel.querySelector("button");
  if (clearButton && clearButton.parentNode === panel) {
    // solution StackOverflow : insertBefore(parent, nextSibling)
    panel.insertBefore(sketchContainer, clearButton);
  } else {
    // fallback ultra-sécurisé
    panel.appendChild(sketchContainer);
  // init Sketch
  const sketch = new Sketch({
    view,
    layer,
    container: sketchContainer,
    creationMode: "single",
    visibleElements: {
      createTools: {
        point: false,
        polyline: true,
        polygon: true,
        rectangle: true,
        circle: true,
      selectionTools: {
        "lasso-selection": true,
        "rectangle-selection": true,
      settingsMenu: true,
  const createHandle = sketch.on("create", (event) => {
    if (event.state === "complete" && event.graphic?.geometry) {
      selectBySketchGeometry(event.graphic.geometry);
  sketchWidgetRef.current = sketch;
  return () => {
    createHandle.remove();
    sketch.destroy();
    sketchWidgetRef.current = null;
    // nettoyage DOM sécurisé
    if (panel.contains(sketchContainer)) {
      panel.removeChild(sketchContainer);
}, [selectBySketchGeometry]);
JSX:
      {/* Styler Panel (utilisé par le widget Expand ArcGIS) */}
      <div ref={stylerPanelRef} className="p-3 space-y-2 text-sm bg-white dark:bg-slate-800 h-auto">
        <h3 className="font-bold text-slate-700 dark:text-slate-200">Sketch Styler</h3>
        {/* Le conteneur Sketch est ajouté dynamiquement via JavaScript */}
        <button
          type="button"
          className="px-3 py-1.5 text-sm font-medium text-white transition-colors bg-blue-600 rounded-md hover:bg-blue-700 focus:outline-none focus:ring-2 focus:ring-blue-500 focus:ring-offset-2 dark:focus:ring-offset-slate-800"
          onClick={() => sketchLayerRef.current?.removeAll()}
          Clear Sketches
        </button>
      </div>
Thank you in advance for your help and feedback.
